Electric Lumbar support S3
Dave1000 Jul 20, 2008
  1. Dave1000
    Dave1000 Member
    202
    Is this worth having does it make the seat more comfortable?
  2. JamS3
    JamS3 Active Member
    2,258
    23
    No mate.
    Had it on my last one and never used it, waste of money in my opinion.
  3. LDoR
    LDoR likes his V6
    61
    Depends on your back really. I find that i adjust mine occasinally as it helps supprt my back depending whether i've been tense at the office or working hard at the gym. It also helps on long journeys almost acting like a massage :)
  4. jamiekip
    jamiekip Guest
    Before getting my car I had an S-line for a weekend demo, then an S3 for an afternoon, neither had electric lumbar support and I could never quite get comfortbale - lower back was never quite comfortable.
    I specced it with mine, and have got it set right for me, but obviously never adjusted since then. So, get a test drive in one without elec lumbar, an extended drive if you can - if you get comfy - no need, if you can't it's a worthy addition!
  5. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Once you have set it you will never change it. So if the std seats already suit you then I wouldnt bother.
  6. JohnS3
    JohnS3 Active Member
    3,032
    I'd say so. For me the seat needs a little more lumbar support, but as suggested already, drive one with and without if you can.
  7. L60N
    L60N Guest
    It goes without sayin - You need to drive for a fair length of time to know whether no lumber is going to give you jip :)
  8. The911SC
    The911SC Active Member
    1,032
    personal opinion but I would say YES as I find the base backrest in the A3 soft. I missed it off my 3.2 ages ago and I have to say the S3 seat is much better. It is true that you probably wont change it but that doesnt make it not worth having..
  9. Oli.
    Oli. Member
    559
    I've got it and i always spec it on my cars, because of my bad back - Works a treat for me.
  10. EAGLE79
    EAGLE79 Member
    339
    Mate i've got it and didn't spec it, car was already built and it was and extra bit thrown in.
    TBH i've used it a few times. Find it good on a long journey as i adjust it to help stretch/ support my back and change its position. Depends how comfy you find the standard seats etc.....
  11. crazylegscrane
    crazylegscrane Active Member
    258
    66
    I had it on an courtesy car and found it gave extra support that the drivers seat lacked.
    Impressed enough with it that I've ordered it on my new S3
  12. Dave1000
    Dave1000 Member
    202
    Thanks Guys think I will have it then
  13. royalsteve68
    royalsteve68 Well-Known Member TeamMisano Audi RS3 Audi S3 Team Ara Blue
    1,146
    293
    depends how old you are or how bad your back is - im old but didn't spec it but now thinking like you - is it worth having - im going to see if my local audi has one and try it - it wont be a perfect test but I just add it anyway - may do the same for the load through option was thinking of colour coding the wing mirrors but I may keep them silver anyway
    I did think about electric seats but every seat ive tried is frustratingly slow - sure memory seats are better but ill probably stick with manual unless someone can sell me the benefit other than sheer laziness
    decisions decisions - so indecisive - lol on the same day I spent >7 times the amount on a new flat to rent out and spent about approx. 1/700th time deciding whether to buy it compared to a replacement or new car, crazy really - cars really do hit that emotional button
  14. royalsteve68
    1,146
    293
    is it me or are audi and other manufacturers missing a trick - seems that a lot of options you have to specify as part of the build and retro fit isn't possible. surely you should be able to buy any option after getting the car and to avoid people having a low spec just make retro fit a lot more expensive
    ive read some comments that if you don't specify electric lumbar support you cant add it later as the electrics are different - crazy, what a missed sales opportunity
  15. royalsteve68
    1,146
    293
    think ill prob add, wonder if electric seats are worth having, then again when do we stop adding options, lol
