Electric folding mirrors supposed to dip down when reversing?
brad9753 Sep 5, 2013
  1. brad9753
    brad9753 Member
    78
    Says it all in the title really. I'm sure I read or heard somewhere that with the electric folding mirrors, the mirrors automatically dip when you reverse. Of am I just making this up? Would look in the Manuel but I am away from home at the moment.
  2. baldrick
    baldrick Member
    49
    Pretty sure you have to have mirror adjustor set to the passenger mirror and it it will dip down when reverse is selected
  3. A3sportbackMark
    A3sportbackMark Active Member
    711
    230
    43
    I tested this out tonight, havn't changed anything in the Mmi yet. On selecting reverse and moving the wingmirror selector to the passenger wingmirror - will dip the wingmirror.
    From what I remember, this should be a programmable feature, will have to play around with it, or even look at the manual.
  4. Fragup
    Fragup Member
    462
    185
    You are correct they do, there is thread on here recently on how to set them up.
  5. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,551
    1,165
    That's pretty much it. Adjust it while it is dipped to save a new position. It's as simple as that!
  6. Daveotto
    Daveotto Well-Known Member Team Floret Silver Gold Supporter Audi S3 S3 Saloon
    2,838
    4,082
    you must do the adjustment with the ignition on and car in reverse gear.
  7. cemerson
    4,551
    1,165
    Well it wouldn't be dipped otherwise!
  8. B7000
    B7000 Member
    56
    33
    Mirror adjustment switch must be left in nearside position, if in centre position it is in off position and will not work.
  9. cemerson
    4,551
    1,165
    Yeh, I leave mine off (in case I knock it by accident), and can dip the mirror if I need it - tricky corner or need extra visibility - but saves everything moving every time I go into reverse then having to move back again
  10. B7000
    B7000 Member
    56
    33
    Mirror moves back to original position automatic when you select forward gear
  11. cemerson
    4,551
    1,165
    Yes, but all takes time - no point if you don't need it. I can use it when I need it.
  12. Schizophonic
    Schizophonic Well-Known Member
    869
    437
    Doesn't the VCDS needs to be involved?
  13. cemerson
    4,551
    1,165
    Only if you don't have it as standard - that's for enabling it on cars that don't have the folding mirrors, the dipping can still be enabled I think
  14. Tom75
    Tom75 Member
    92
    14
    Hmm, I have to try this myself or maybe I misunderstood the thread title "[h=2]Electric folding mirrors supposed to dip down when reversing[/h]"
    but what is the idea if the mirrors dip down when driving backwards? How are you supposed to use them to see whats going on in the back?
    Regards,
    Tom
  15. Fragup
    Fragup Member
    462
    185
    i thinks it's so you can see down to the kerb better when parking.
  16. Dylock
    Dylock Active Member
    269
    71
    I don't have mine on permently, if I'm parallel parking I switch it on, all other times it off.
    Worth noting that each key will save it in their own positions.
  17. RossR
    RossR Active Member
    501
    122
    43
    also for when reversing round a corner. It's only the nearside mirror that dips.
  18. Tom75
    Tom75 Member
    92
    14
    Ok, thats cool then, need to try it.
    Regards,
    Tom
