Eibach springs
neilA4 Aug 13, 2010
  1. neilA4
    neilA4 Member
    206
    Fitted a set of Eibach springs a while back, the ride height on the back is fine, the front is uneven? The passenger side sits 10mm higher? I thought it would settle but has not!
    Can it only be the springs causing this? I can't think anything else would determine the height!
    I'll have to swop them over side to side and measure them at same time?
  2. aragorn
    17,896
    689
    perhaps they're not seated properly in the rubber pad things?
  3. neilA4
    neilA4 Member
    206
    I'll check it all out tomorrow, the passanger side def has more travel than the driver side! Would a blown damper have the same affect?
  4. aragorn
    17,896
    689
    not really, spring holds the car up.
  5. neilA4
    neilA4 Member
    206
    well stripped the suspension, springs are same height etc but spot the difference lol
    would this be the cause of the height difference? the inside of bump stop has disintergrated! Does the suspension sit on the bump stops then?
    audi want about £17 not sure if it includes vat, the other one is solid
    cheers
  6. voteforpedro
    voteforpedro Member
    632
    Check for dead bodies in the O/S/F wheel well. Sometimes they get stuck up there.
  7. voteforpedro
    voteforpedro Member
    632
    Damaged bump stop wouldn't make a difference. They're only there to cushion the blow and protect the internals when the piston becomes full depressed.
  8. adamss24
    adamss24 Well-Known Member
    4,553
    393
    Are the springs the same load rating ? I would check the markings on them as they might be different wich will explain the difference....
  9. neilA4
    neilA4 Member
    206
    springs have same numbers, only difference I can find is the bump stop, which is listed in Etka as a 'helper spring'
    will see if it makes any difference tomorrow ta
  10. voteforpedro
    voteforpedro Member
    632
    Did you cut the bump stops down?
  11. neilA4
    neilA4 Member
    206
    nope no need not lowerd car really
  12. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    what do you weigh?! ;)
  13. neilA4
    neilA4 Member
    206
    cheeky git
    I have now changed bump stop, and the height difference is ******* worse!
    I'm now going to try changing the complete spring/damper assembly's over and see what happens.
    :banghead:
  14. aragorn
    17,896
    689
    have you made sure the spring is against the stop on the rubber pad, and in the lower mounting collar?
  15. adamss24
    4,553
    393
    Thats a good point, the sports bump stops are lower than the SE bump stops hence they will desintegrate quicker. I would make shure you put new sport items IF you have standard suspenssion fitted on the car from factory !
  16. neilA4
    neilA4 Member
    206
    sports suspension is standard on tqs, bump stop replaced has same part number, but instead of being red it was cream coloured for some reason, same length though. Think tqs is 25mm lower as standard and the eibachs are 30mm so only 5mm in it.
    it was against the stop on the upper and lower pads, will have another look friday afternoon, working nights so will have to wait till then lol
  17. neilA4
    neilA4 Member
    206
    well i have tried swapping the damper/spring assemblys over and made no difference so that rules them out. The subframe bushes seem ok.
    Have measured the difference and it's 15mm higher on the passenger side.
    Would the anti-roll bar have and influence on the height? suppose i could unbolt the c links and see what happens?
  18. neilA4
    neilA4 Member
    206
    tried unbolting the c links and that made no difference whatsoever!
    wonder if the top mount plate (that the upper arms bolt to) is damaged. the side that is lower is the side that had the damaged bump stop on so may have taken a hit at some point?
    gonna have to srip it all down again.....meh
  19. auroan
    auroan Active Member
    1,669
    can you put the original springs on to compare ?
  20. neilA4
    neilA4 Member
    206
    ive tried swapping the springs over side to side and passenger side was still lower! also tried swapping the dampers over made no difference.
    last thing I do will be putting the old springs on, could of been same with old springs but just not noticed
    cheers
  21. aragorn
    17,896
    689
    If you've swapped the springs left to right and the same side is still lower, then it cant be the springs...
    Perhaps one side of the car is heavier? Either that or the rubber bushes on one side arent in the right "place" which will be adding to the spring rate slightly?
    Try slackening off the big bushes on the ends of the wishbones, then retighten them with the car on the floor (or jack each side up so its at the correct ride height before tightening)
  22. auroan
    1,669
    I think there are some procedures you do on the suspension which must be done with the full weight of the car on the ground, otherwise you can get this issue. I'll dig out my erwin pdfs tonight and send them over if you want. Pm me your email addy.
  23. neilA4
    neilA4 Member
    206
    pm sent cheers
