Eibach Springs arrived
Macdoon Apr 4, 2013
  1. Steve220
    Steve220 Member
    234
    15
    Mac, out of interest, on fitting is there a nut holding the centre shaft of the shock to the top mount or is it attached another way? Only reason I ask is I think there maybe another way of fitting springs without removing the top control arms and that annoying pinch bolt. Car sits very well on those springs and that wheel combination!
  2. Macdoon
    Macdoon Well-Known Member Team Ibis TFSI Owners Group Gold Supporter Audi A4 S-line owners group
    2,024
    795
    Hi Steve, here's a pic of the top nut that was removed
  3. Tiffy
    Tiffy Active Member
    363
    89
    The more i look the more it seems to be the same hight....i have even put them pics together on photoshop.
    I will be measuring mine before and after in the workshop i think.....
    Like you say, Hopefully it will settle a little more
  4. Tiffy
    Tiffy Active Member
    363
    89
    Are you rims 18's or 19's.........
  5. sewell10
    sewell10 Member
    236
    Looks sweet mate
  6. ajax1976
    ajax1976 Well-Known Member
    1,279
    656
    Can be done without removing the pinch bolt but it's a bit fiddly. Raise the car and support it then jack up the wishbone to compress the spring. I couldn't get my spring compressors in to hold the spring so used several lengths of binding wire to hold the spring under tension then let the wishbone back down, just make sure the spring is securely bound down. Then it's just a case of removing the bottom and upper bolts and that lets you remove the whole lot at once without touching the pinch bolts. Sounds easy but it's still a fight tbh, I found it easier and quicker to remove the pinch bolts.
    Looks great tho Mac, big improvement. My H&Rs dropped a wee bit over the couple of weeks after fitting.
  7. V6 Quatt
    V6 Quatt Well-Known Member
    1,248
    439
    Agree
  8. V6 Quatt
    1,248
    439
    Great Work mac - looks much better....yes it will settle and sit a bit lower after a few hundred miles etc.
  9. Macdoon
    2,024
    795
    great news, now to sort out the next mod lol
  10. V6 Quatt
    1,248
    439
    Here is a view H&R once settled with 18's on 19's going on soon
    Macdoon likes this.
  11. davsa4
    davsa4 Member
    257
    19
    looks loads better mate , now get some 15mm spacers on the rear and fill those arches :thumbsup:
    as for the pinch bolts when i fitted mine i removed the two rear bolts that attach the upper arms to the strut top and left the pinch bolts intact a bit fiddly but reduces the risk of the bolt snapping or the upright breaking as in this post .
    regards dav
  12. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Looking good MAC, can't wait to get mine lowered now!
    As for the method you mentioned Dav, aren't these said bolts quite tricky to get at and undo? I may just go about this method when fitting mine.
    Thanks, Az.
  13. Steve220
    Steve220 Member
    234
    15
    My spring compressors are compact and will easily get in either side of the spring. I think if i do ever adjust or modify the suspension in anyway, this is how I will get the shocks out. The Audi A4 haynes manual does explain a lot of it, but personally i'd have done it all another way. Advantage of being an ex mechanic ;)
  14. davsa4
    davsa4 Member
    257
    19
    yes mate they are a bit tricky but not too difficult .
  15. Macdoon
    2,024
    795
    Thanks mate, the offset is currently et35 so realistically how far out can I go without rubbing front and back
  16. ajax1976
    1,279
    656
    I don't think you can go anymore than 3mm spacer if you're et35 at the mo. I tried et30 on the rear of mine with an 8.5j 19" wheel 235/35 tyres and had light scubbing over speed bumps. Now I'm et32 on the front and 38 of the rear and have no scrubbing.
    Are you sure you're definately et35? Once its settled you'll get a better idea what if any spacers it'll need.
    Just remembered I was et32 on the rear with my 18" S4s with 225 tyres and had no scrubbing.
  17. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    If it helps, my rear wheels are 19" 8.5j 235/35 ET48 with 15mm spacers (ET33) and no issues here. :sm4:
  18. Macdoon
    2,024
    795
    Think i'll leave as is, thanks for the info
