Eibach Pro-Sport
glasgowdubber Mar 25, 2010
  1. glasgowdubber
    glasgowdubber Active Member
    335
    61
    Anyone running these springs on an S3?
    Just ordered them today 30mm, then was called back to be told they would only lower the car 20mm because the car has air suspension?
    My mate had them on the MK5 GTi and they were excellent, I would go as far as saying better than standard..
    Will 20mm really make any difference? I'm planning on getting 19s for the car soon so didn't want to just leave standard springs on.
    Chris
  2. Boydie
    Boydie Boycie VCDS Map User
    3,237
    339
    My S3 is lowered 25mm on H&R springs - it could honestly go a bit lower at the back but I am perfectly happy the way they sit!
  3. NHN
    29,295
    1,701
    Eibach pro's IMHO are just right, not to low & certainly not too high, they ride well too.
  4. glasgowdubber
    335
    61
    Excellent cheers guys, I know most people use H&R but company I am dealing with don't really deal with H&R.
    Boydie are you running 18/19s? You got any pics? Would appreciate it before I commit to having these fitted.
    Chris
  5. Y444GAR
    Y444GAR Member
    198
    Eibach pro's for the s3 are front springs only. 20mm.
  6. glasgowdubber
    335
    61
    What lowers the back then?
  7. Y444GAR
    Y444GAR Member
    198
    Nothing, the set has just got front springs. The rear doesn't get lowered.
  8. glasgowdubber
    335
    61
    Just phoned the company who are doing it and they said the rear of the car will drop to match the front if the front lowers? Is this correct, or complete bull****?
  9. Y444GAR
    Y444GAR Member
    198
    I have a set of eibach pro's in my garage waitin to go onto my car. Just 2 springs. Check all the websites that sell them.
  10. thebott
    thebott Member
    211
    I am also on 25mm h&r springs with 19" sits just fine for me . no rubbin..............
  11. glasgowdubber
    335
    61
    You've just made my mind up £280 to supply and fit 2 springs is crazy! Cancelling the Eibach tomorrow and ordering H&R.
  12. gingers3
    gingers3 Active Member
    678
    119
    43
    i thought the H&R s lowered 35 mm ? if they only lower 25 mm i m going to order some
  13. jsws3
    jsws3 Member
    440
    Awesome gti are the cheapest to buy H&R from mate
  14. Y444GAR
    Y444GAR Member
    198
    280 for the eibachs, you were done anyway.
  15. glasgowdubber
    335
    61
    £140 for Eibachs, wanted another £140 to fit.
  16. N8
    17,163
    718
    Most run H&Rs springs
  17. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    £140 beans to fit 2 springs? I'm obviously in the wrong business!
  18. N8
    17,163
    718
    4 springs? :ninja:
  19. NHN
    29,295
    1,701
    Not at all scott, you try removing the hubs of each front corner, swapping the suspension over then refitting it, it isnt as easy job as it seems to be, done it twice on mine mate, although straight forward mostly if you have all the tools & there are no siezed nuts/bolts, it does take time to do plus an alignment is needed, so for me £140 is actually about right & maybe even cheap tbh, rears are a hell of alot easier generally.
  20. scottie123
    1,972
    I must have been lucky when I did mine then!
    Everything came apart nice and easy, Except splitting the hub(but if i had the right tool !)
    Didn't take too long, Like I say, mine was quite easy though. No probs or seized bits :)
  21. NHN
    29,295
    1,701
    How many hours did it take?
  22. scottie123
    1,972
    I would say a very leisurely 2 hours. lot's of tea and fags :)
  23. scottie123
    1,972
    That's just the fronts though
  24. NHN
    29,295
    1,701
    2 hours, you were either very very lucky or your idea of 2 hours is more like 4 lol.
  25. scottie123
    1,972
    LOL!
    I must have been lucky then, but i'm sure it was around that time for the front, and I had to use some real pony spring compressors aswell! Thought I was going to lose a limb at some point:scared2:
    Used to working with mechanics though, as I build industrial cnc machinery for a living:)
  26. NHN
    29,295
    1,701
    Then you did well mate, yeah those spring compressors are worrying huh, if they go of then see yer lmfao
  27. scottie123
    1,972
    Nipped buttocks while tightening wasn't the word! :lmfao:
  28. NHN
    29,295
    1,701
    lmfao
