Eibach Pro Kit Plus opinions
chesterdog Dec 27, 2004
  1. chesterdog
    chesterdog Member
    32
    I have a 1998 Audi A4 2.8 Quattro and want to upgrade its suspension set up. I am not too concerned with lowering the car as much as possible, I only want it to handle better. As of now I am experiencing heavy body roll and lift off oversteer. I have looked around and it seems like the best set up would be the Eibach Pro Kit Plus which includes springs, shocks, and a front anti roll bar which should help with the oversteer problem. I wanted to know if anyone had tried this set up and what they thought about it. Also, what sort of problems might this cause in regards to the suspension geometry, camber, toe in etc. Thanks.
  2. sure you dont need new rear tyres if your getting lift off oversteer?
    i wouldnt get an uprated front atb and not a back, the first one too upgrade is the back one or you will get heavy understeer.
  3. chesterdog
    chesterdog Member
    32
    I have 18 inch RS4 wheels with new tires on the way, so hopefully that will cure the oversteer which would make the ARB pointless. What do you think about the Eibach Pro System without the ARB?
