Eibach or H&R springs for 2.0T quattro
co55ie Aug 29, 2006
  1. co55ie
    co55ie Member
    305
    I have been trying to find out if Eibach or H&R do lowering spring for the 2.0T Quattro . I have found the 3.2 Quattro listed by both manufacturers but not the 2.0T Quattro. Obviously the 3.2 springs would fit but the front ones would be the wrong rate due to the 3.2's heavier engine.
    Has anyone else lowered a quattro 2.0T Sline ?
  2. DPM
    DPM Site Sponsor Site Sponsor
    5,106
    229
    We do a 25/30 H&R kit for the 2.0T if your interested?
  3. co55ie
    co55ie Member
    305
    I was looking for more around the 40mm mark as my cars an S line which I believe is about 20 - 25mm mm lower than the standard spec.
    Are the H&R springs for the FWD 2.0T or the Quattro ? as I havent been able to see any specifically for the quattro and wouldnt have thought the FWD springs would have been suitable . Although I maybe wrong
  4. DPM
    5,106
    229
    They're for the Quattro mate!
  5. tinka
    tinka Guest
    i bought kw springs for mine they lower it 40mm,but ive not fitted them yet because of the steering issues
  6. marriedblonde
    marriedblonde Active Member
    4,381
    13
    Don't bother with a 40mm drop, you will not notice the drop in height.
    Look in the sticky post pics of your car thread, you'll see some pics of my xcar, standard, eibach prokit and eibach sportline. you can only really notice a difference with the sportline kit.
    What shocks are you going with?
    J.
  7. Covenant
    Covenant Member
    246
    Not experienced it myself, but allegendly the H&R kit is a slightly more comfortable ride.
  8. marriedblonde
    4,381
    13
    See I heard the opposite!
  9. co55ie
    co55ie Member
    305
    Thats the problem all the main maufacturers only list dampers for the FWD or 3.2 quattro and not the 2.0 quattro . Koni Bilstein etc etc
    I have considered KW variant 3 who again only do a kit for the 3.2 quattro but can make some different springs to suit the lighter 2.0t front end . But I am not sure if I want to go with the coilover route incase the ride becomes overly harsh
  10. co55ie
    co55ie Member
    305
    How much does the sportline kit lower the car by ?
  11. tinka
    tinka Guest
    no need to go to mad,i thought the 40mm drop was a good compromise between to pro kit and the sportline,the prokit lowers 10mm over the standard s line suspension,so the kw's will give a 20mm drop over standard s line,or another way to look at it is 40mm over a standard a3?.
  12. wilko
    wilko Top Gear
    725
    What about the Sport suspenssion, what are the drops on the sport? And how do changing your springs effect your warrenty?
  13. marriedblonde
    4,381
    13
    The prokit only lowers the s-line by approx 5mm
    The sportline lowers by 45mm/50mm.
    With the Prokit.
    With the sportline kit.
  14. co55ie
    co55ie Member
    305
    Looks great with the sportline kit fitted thats the sort of drop I am after but they aernt available for my bl00dy car !!!!!!!!!!!!!! Lol typical.
  15. wilko
    wilko Top Gear
    725
    Is the ride improved with either or both??
  16. co55ie
    co55ie Member
    305
    How does the car cope with speedbumps and silimar with the sportline kit fitted ?
  17. marriedblonde
    4,381
    13
    With the eibachs the ride is better than standard S-line. not stiffer but definately less choppy.
    The ride with the sportlines is stiffer but not that bad. I'm not some 20 year old boy racer and do appreciate some sort of ride comfort especially as I cover 25K miles a year in it.
    Speed bumps are not really a problem, occasionally if I go over one with a bit too much vigour the sh!t tray under the engine scrapes.
    J.
