EGT sensor thread size
Andy123 Apr 27, 2011
  1. Andy123
    Andy123 Member
    260
    Has anyone got to hand the thread size for the egt sensor? Off an 01 amk. Need to get a boss tapped but don't have the sensor to hand. Thanks Andy
  2. aragorn
    18,544
    865
    M12x1 rings a bell, but dont take my word for it.
    I can check at lunchtime for you to confirm.
  3. Andy123
    Andy123 Member
    260
    That would be helpful if you can buddy. From memory I think it was m12x1.0mm or 1.25mm.
  4. aragorn
    18,544
    865
    confirmed, its M12x1.0mm
    Bear in mind if your getting something made to hold it that the bolt down collar is loose, like a brake union. It seals and is held in place by way of a tapered seat at the bottom of the hole, which butts up against a sort of ferrule on the sensor itself.
  5. Andy123
    Andy123 Member
    260
    Thanks for confirming that.
