EGR valve location on 3.0 v6 tdi engine
.Jas. May 2, 2012
  1. .Jas.
    .Jas. Member
    134
    Hi all, I want to clean my EGR valve to see if it helps with some cold running issues I have at the moment.
    I've searched posts for this, but can't find any answer as to where the damn thing is located on the 3.0 v6 engine!
    My best guess is that it's in the middle towards the front, but I'm not sure, any ideas? Pictures would help if possible.
    Also, how easy is it to remove, clean and refit, has anyone done this before?
  2. Joe_Murphy21187
    Joe_Murphy21187 S-Tronic
    1,053
    69
    I don't know, but I'm having it removed at a garage on Saturday so can tell you after that...
  3. .Jas.
    .Jas. Member
    134
    Are you having it replaced or completely removed and blanked off?
    Any help appreciated if you can find where it is!
  4. Joe_Murphy21187
    1,053
    69
    I'm just having it disabled. Little point in having it blanked off or removed as if it's delected from the ECU code it remains closed permenantly. Then if it needs to be re-enabled (for any reason), it should just be a case of re-instating the code (after cleaning it most probably). I'll keep you posted on Saturday
  5. .Jas.
    .Jas. Member
    134
    ok cheers
  6. Joe_Murphy21187
    1,053
    69
    Hi Jas, sorry for the late reply, had a hectic weekend. I didn't manage to find the exact location of the EGR as it was just disabled in the ECU and not removed. Sorry I could be of no help. If you take the cover off the engine and follow the piping from the turbo it should be fairly easy to find...
  7. bdub
    bdub Member
    It is between the cylinder banks, attached to the egr cooler next to the right hand inlet manifold.
  8. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,183
    2,662
  9. adamss24
    adamss24 Well-Known Member
    4,578
    402
    Look for the shiny silver actuator with a rubber hose going to it...
  10. .Jas.
    .Jas. Member
    134
    Cheers guys, I think I know where it is, and it looks almost impossible to remove! :sadlike:
  11. bdub
    bdub Member
    not as bad as you think to remove - get a copy of the elsa off the bay and it shows you- i can't work out how to post pictures on the forum.
  12. mongs
    mongs New Member
    Hi, I need some help guys.
    I keep getting these fault codes;
    2 Faults Found:
    4807 - EGR System: Insufficient Flow
    P0401 00 [096] - Short to Ground
    5215 - Fuel Rail/System Pressure: Too Low
    P0087 00 [032] - Cannot Be Tested at this Time
    Car has done 100k miles/160k km, and I'm thinking it is EGR valve that need to be cleaned. What do you think?
    Engine bay looks like a rats nest and I'm not really sure where to look fot the EGR valve :)
    I hope someone wiser can show me, here is the pic of engine:
  13. carl-1968
    carl-1968 A4 sold, lots of bits available, ask for details
    538
    30
    I got mine blanked and deleted from the ecu roughly located r/h side towards front of engine, aproxx 1 1/2 inch dia braided pipe between exh and inlet, i'll send you a pic if you pm me as i still cannot post pics or vids on here!
    Carl
  14. gupsterg
    gupsterg Active Member
    348
    Perhaps no use now as you posted so long ago but I came to this thread via a google search and thought perhaps place the info for if another in future turn up...
    Yours to me looks like the later engine code CAPA 3.0 TDi V6 (same for later 2.7 TDI engine code CAMA & CAMB)
    Red box is electronic EGR control valve... green box is the vacuum operated EGR cooling flap solenoid...
  15. .Jas.
    .Jas. Member
    134
    I blanked mine, but when the car went in for some work I got them to remove the EGR and clean it - but it was already clean, so I unblanked it again. Getting to the location of the EGR was a bit too much for me.
  16. .Jas.
    .Jas. Member
    134
    mongs - it might be worth blanking it first to see if it helps, it's an easy job to blank it. It will bring the engine light on though.
  17. mongs
    mongs New Member
    I did change the EGR valve, seems like the problem is (almost) gone. I've driven at least 10tkm with it and only once have gotten the same error code (no MIL light)
    The EGR I removed, wasn't busted or clogged but the replacement valve has worked better (error-free). Maybe it was electrical faul in the EGR, since it the flap is PWM-controlled..
  18. gupsterg
    348
    How much did you guys pay for EGR delete from ECU?
    TIA
    G
