EGR - remove&blank, or clean&keep?
Have you kept or removed your EGR?
  • Removed EGR and blanked off.
    Votes: 22 64.7%
  • Cleaned EGR and re-fitted.
    Votes: 12 35.3%
  • Total voters
    34
DALE_AVANT
As title, just interested in the general numbers of forum members that have removed their EGR valve, when compared to those that have actively decided not to remove it.
Any B6 1.9 TDI 130 reasons/experiences would be personally welcome, but all feedback in relation to the poll and EGR welcome.
Hi, recently I have took my egr valve off and cleaned it. I strugled a bit with the bolts which were a bit rounded off however I managed to get them off with the alen key. I went to the steelers and bought the egr valve gasket and new bolts which in my case were necesary. I have cleaned it with petrol, put the whole unit in petrol for about an hour or so and used a metal brush to clean all of the carbs off. I have blanked the egr with proper metal plate. I've heard of people using tin cans cut to shape to block it off however apparently after few months it blows it's way through.
Easy job and made a big difference in my car's response to the accelerator pedal, definately worth it.
Reactions: HugsterTDI
i took mine off to clean but was surprised it did not need cleaning it did look a bit black and sutty but there was zero carbon build up . i can only put this down to the regular use of forte diesel treatment . unfortunately i ended up replacing the egr valve due to a split rubber diaphram in the anti shudder valve
mine didnt have much carbs either poss 1mm so I was surprised aswell, my car never had any of that ****e put down my fuel tank. Recently I've cleaned my mates 2006 mondeo egr and inlet manifold and there was 6-7mm gunk... the mondeo has 130k miles and mine has 110k..
Just fitted the Allard delete kit to mine, all seems fine but a bit early to compare fuel figures, but the flat spot I had seems to have gone and the back of the car sure is a lot cleaner!
What's the main difference between the Allard kit and a DIY delete? Do they both cause the engine management light problem?
Couldnt you have just blanked off the EGR rather than replace it ?
anti shudder valve[/QUOTE]
I'm guessing this could create shuddering at idle? Just minor? As mine is doing this, and my EGR was quite oily, had it cleaned the other day as it's a bit leaky. ( outside only )
I get no engine management lights atall with the Allard kit.
I'd like to know more about this, on eBay there's a 2mm custom plate that has been made to blank off the EGR and it's £4 delivered.
EGR valve blanking block off plate 2mm T4 T5 T25 transporter R5 R6 TDi pd A3 A4 | eBay
Heard about golf tee's duct taped into pipes etc so I'm hoping to find out what to do and is it worth it too? Good link AUDIESEL.
I do keep wondering about this, if you go down the Allard route its like £56 for the kit!!! or as above you can buy blanking plates and just get rid of the standard EGR...decisions decisions..........
all i did was put a blanking plate on
you will be paying out more money for the allard kit and it does near enough the same thing it just stops the exhaust gasses circulating yes the allard might be more pleasing to the eye but at that price no thanks
i made the blanking plates so cost me nothing and your not going to gain with the allard you will just loose £56!
I have had the fault on my 1.8t that the secondary air system detected wrong way air flow. would my EGR be screwed then?
does it sound like you got a dyson under the bonnet m8..... your secondary air unit is rivited together and eventually the rivits come loose causing it to loose air and cause a fault doubt the egr is your issue...... they can be drilled out and 5mm bolts fitted
That Ebay plate, wouldn't it need a gasket to stop it leaking?
I'm wondering that too. Could do with some pics, instructions and conclusions. Like the idea of more power economy and running smoother could just do with knowing at what cost and cane someone of my fairly novice skill do it myself...:think:
You get slightly better mpg due to the car burning cleaner but your talking 1 to 2 mpg max
The main advantages would be the egr won't soot up and stick the inlet manifold would not soot up and you won't get leaking gunk from the egr
so why all the blanking off? just un-plug the sucker pipe at the EGR valve and stick a screw bolt up the pipe to seal the vac system. job done.
I'm at home today and will do that to see what happens, heard about someone doing this with a golf tee recently!
I bought and fitted that, better throttle responce and burns cleaner to.
Blanked mine off today but the EML came on after a while. Shame because the car felt more responsive:banghead:
Any thoughts on blanking plates vs Allard pipe?
As I understand it the Allard pipe would affect the anti-shudder valve?
with the allard pipe it's a nice clean pipe,unlike the egr pipe with bits in the middle,so I'd say its easier to pass through so more beneficial to the car. It does affect the shudder,a little wobble at turn off!
also it has an outlet on the pipe,in case you want to run boost controller,monitor.
it comes with a blanking plate too. Bit pricey yes the kit,but I got lucky on eBay at £40.
I thought after a certain year the ecu monitors the egr?
i know our 2000 Golf doesn't as I've pulled the vac pipe on it before but our 2004 plate Golf puts the EM light up but doesn't effect the actual running of the engine.
i keep meaning to try cleaning our Golf's egr out and blanking the vac pipe and see how it does. The car suffers from random boost deviance so I'm tempted to loose the vac pipes that I don't need anyway to try and find the problem for that aswell
How much of a wobble is there, and is this detrimental in any way to the car?
Never had a problem with mine.
Do you get any shudder at all?
Deffo worth cleaning, they can get pretty grubby in there
You could just take the vac pipe off the feed to the shudder valve to see how that feels.
dont forget that the anti shudder valve also could stop your engine running on if it suffered from diesel runaway. But on a well maintained at that is a very small risk
You do notice judder.some worse times than others.
Newer models think from 02 not sure,bring on the eml with egr delete.
A good mapper will be able to delete it.
Got mine deleted with remap
audilad9 ]My car is an 04, EGR gone, no light ever.
When you start ur motor,does mil light come on then go off?
No shudder, nothing, the kit has made no difference.
Deano1978 Yes the light illuminates and extinguishes as should do. AVF engine. When I first got the car I disconnected the vac line to the EGR and left it like that for over 2 years, my manifold was fairly clean when removed to clean inside it, delete EGR also mr muscle the turbo but its still only at 88k miles. I always use miller sport 4 fuel additive, I don't know if this helps to keep things clean outwith the fuel system or is there any trace after combustion but for all the cost why not, It says it improves power :) Car goes very well :racer:
I want a decat like yourself Deano1978 but am scared of breaking my turbo shaft, I do drive quite hard, is it worth doing ?
Crazey? Soon as i put a plate on mil came on and tried with it just unplugged,still came on!
I use the eco stuff from halfords. mr muscle has been down there too.
I'd say i have a strong remap as i can wheel spin in 3rd (in the dry) but dont if ever do it, im very wise with my torque,pulls in 6th very well too.
I put it down to the mapper.
Told him ive the direct cold air intake,free flow exhaust and wanted the egr delete,boy did i notice a difference.
Im still catted from the turbo,just middle and end cats removed. Not sur about full decat as sone stories say the turbo can over spool,but also say spool up time is quicker again,Hmmmmm
i reccommend the cats removed center and back and ur notice an improvment
Yeah, strange one that about MIL.
I have a strong remap too, it even sounds aggressive compared to standard ! I have a cold feed induction kit also and instead of spinning the wheels, I could if I tried spin up the clutch in first to third (quattro), you need to be gentle with the torque. I know there are guys on here with a lot more power than me, but my clutch etc are all standard for now, the tyres don't like it at all !
So you still have your catalytic convertor and you have removed the silencer boxes/baffles ?
I would remove my cat if I thought it wasn't going to break the turbo. I aim for healthy useable power,with improved economy or else I would have bought a S4 :)
Sorry for deviating from the thread topic.
Which vac pipe need to be pulled and blocked to test run this?
Clean it out and had to to keep on mine due to the light popping up being a 2004.
I did fit a smaller holed egr gasket from the mk3 Ibiza that vastly reduces the gas flow but allows enough not to trigger the EML light.
Works a treat and feels really punchy in most gears for a none mapped car
942
21
4K
3K
5K
