Egr removal. Where do I get the parts from
dubindan Apr 13, 2013
  1. dubindan
    dubindan Member
    97
    So I'm considering removing my egr valve and cooler I allready have my car mapped and I don't want to change the map so can the egr system just be switched off without a new map, also has anyone else done this rough costs and where do I get the parts from thanks
  2. Boon
    Boon Active Member
    441
    59
    You'll need the EGR mapped out, you can't remove it (without engine management light coming on) unless you asked for it to be mapped out at the time of the remap.
    The parts to block & pipe connector to remove the cooler are on eBay
  3. dubindan
    dubindan Member
    97
    Hmm think I won't bother then dont want to pay out for another remap
  4. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    883
    You shouldnt be paying out for another full remap as its only an update to your existing map. The EGR is programmed to stay fully closed and thats all it is. Should cost no more £50 to get the update IF that. I only charge for 1 hour labour and its a quick tweak to the map so no worries. Ask your tuner if they can do it for you and on't be fobbed off that it has to be a full remap because it doesnt need it. Update only mate
  5. Johnny Bravo
    Johnny Bravo 6+1 Gears Bronze Supporter Audi A3
    898
    69
  6. harvz
    harvz Member
    72
    It cost me £25 extra to get a egr removal after i had a remap, i dont think it requires a "full" remap. Ur better of going to remap guy to sort it. Hope it helps
  7. Smillie13
    Smillie13 Member
    933
    45
    Listen to Brodster that what he does :)
  8. dubindan
    dubindan Member
    97
    And looking at my egr it looks like its linked to a oil cooler is it is it safe to remove the cooler too ?
  9. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    I have had my egr cooler removed and egr valve and has caused no problems.
  10. tdi-man
    1,783
    64
  11. tdi-man
    1,783
    64
  12. dubindan
    dubindan Member
    97
    Okay I'll get it done then thankyou my coolant is slowly going over a month and its starting to let out a lot of steam and blue smoke until its warm. My mechanic told me usually the cooler causes this so I want to get rid of that anyway.
  13. S3AMK20VT
    S3AMK20VT Member
    170
  14. dubindan
    dubindan Member
    97
    Okay cheers can any remaper turn it off for me or has it got to be the one who's put the map on it
  15. Brodster
    3,548
    883
    Would be easier for the original tuner to update the map as he loaded it up. Just ask him as this shouldnt be a problem.
  16. dubindan
    dubindan Member
    97
    Okay thankyou
