EGR leaking lots of oil - How to stop this?
scottshere Jan 7, 2012
  1. scottshere
    scottshere Member
    369
    How do you stop the oil from leaking out the EGR and onto the airbox
    Would cleaning it out help or changing rubbers or is it a case of a full replacement
    I have blanked the EGR off and got the EML on, but living with this.. Thought the oil would stop after blanking it off
    Any thoughts?
  2. tdia4
    tdia4 TDIPOWARRR
    613
    Mines doing the same, its leaking from 2 small holes either side of the EGR valve, I'm getting a proper blanking kit for it now which will stop it, see if yours if coming from the same place.
  3. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    It's the exhaust fumes mixing with a bit of oil mist from the air intake
    Blanking off the egr will stop it and clean the egr too
  4. scottshere
    scottshere Member
    369
    Blanked it off already at the manifold only though... Have stuck a golf tee in the Vac pipe on top, but not touched the other Vac pipe
    Maybe i need to get it off completly to clean it out and see if it is actually still leaking.
    What could i use to get the oil off the airbox etc?
    I have got some turps in the cellar
  5. tdia4
    tdia4 TDIPOWARRR
    613
    Get another blanking plate to actually go onto the egr valve, i've got one on mine but it does still leak but as mentioned above mines coming out of the 2 small holes either side of the egr valve, then its dropping onto the exhaust.
  6. scottshere
    scottshere Member
    369
    Will do that and see if it helps
  7. MrG A4
    MrG A4 New Member
    27
    'Wynn's fuel injector air intake and carburettor cleaner' is pretty good at shifting thick oily deposits, it comes in an aerosol can costs about a fiver. Not sure if it is suitable for use on plastic, I've used it sparringly on few plastic components without any problems - should be ok.
