Egr leak
mattyb6 Mar 4, 2013
  1. mattyb6
    mattyb6 Active Member
    977
    75
    Would a leaking egr gasket cause really bad mpg on a 1.9 pd130?
  2. S3 GAZ
    S3 GAZ Member
    381
    17
    I have a leaking egr gasket on my 130pd quattro and get 42 - 44 mpg on dis.
  3. mattyb6
    977
    75
    I think it's leaking, but in getting 20-35mpg, I know it needs a temp sender and stat.
    But don't know if anything else could cause poor mpmpg
    i used to get 55-60 easy last year
  4. S3 GAZ
    S3 GAZ Member
    381
    17
    Stuck open stat will cause overfeuling if engine is not reaching operating temperature.
    Theres a good chance its this and not a dodgy temp sender. Was on mine
    Will cost £6 -10 for a new one and is relatively straight forward to change.
    Youl need some coolant to top up
  5. mattyb6
    977
    75
    I'm mechanically ok, I'm going to replace stat and sender as they next to each other and both need coolant to be dropped. So be ride not to in my opinion
  6. S3 GAZ
    S3 GAZ Member
    381
    17
    If looking at the engine from front of car. Stat is bottom right behind alternator. Temp sender is at back of engine infront of bulkead. Its under boost hose that goes into egr. Its a bit fiddly to get too.
    But may as well change them both if your dropping coolant out.
  7. mattyb6
    977
    75
    I thought the sender was next to the stat, but it was at the bulkhead on 1.8t?
    either way I will look behind the egr.
    Thanks.
    Hopefully this will bring some mpg's back :)
  8. S3 GAZ
    S3 GAZ Member
    381
    17
    No probs mate. Yeh different location on the 1.8 t
    Let us know how you get on.
