EGR 'insufficient flow' and MAF sensor.
rickyquicky Jun 26, 2011
  1. rickyquicky
    rickyquicky Member
    342
    My 2.0tdi BKD engine recently came up with a fault code which was 'EGR insufficient flow'.
    The EGR valve was changed about 9 months ago for the same fault, which was supposedly cured until recently.
    Now it has came back, I have been told it could in fact be the MAF sensor, and the engine management is mistakenly throwing out an EGR valve fault.
    Anyone with experience know? Can a MAF fault show up as EGR on diagnostics?
    The only 'fault' that is evident is that perhaps the car is not a fuel efficient as it used to be. TIA [​IMG]
  2. a8 tech back
    a8 tech back Member
    198
    if the airmass fails it defaults the egr to off or visa versa
    final control the egr vacuum black body on the bulkhead
    the unit leaks internally and therefore insufficient egr vacuum hence through put to low
    the black solenoid box is the likely culprit and not the mechanical egr or the airmass
  3. NHN
    29,284
    1,695
    Urm I thought the solenoid valve blocks were fairly bulletproof tbh mate, history of faults?
  4. a8 tech back
    a8 tech back Member
    198
    no nhn, there not although rare through put to low is insufficient vacuum or sticking egr mechanical valve
    as the egr valve is designed to operate in such a dirty area they very rarely stick and its often misdiagnosed but the valve body general pings this fault and you clear it and then it return some times 3 months later
    normally a sporadic fault and rarely static
    done a few after every tom **** and harry has looked at them and give up because they think there faultless.
    exposure to the weird faults gives wisdom lol
  5. NHN
    29,284
    1,695
    Yes, sometimes the thought out of the box & not following the advised line, can produce a fruitful result lmfao.
    Enlightening info, thanks.
  6. rickyquicky
    rickyquicky Member
    342
    Thanks for the help and info a8tech, so just to confirm it could in fact be the MAF sensor at fault but showing up as EGR fault right?
  7. a8 tech back
    a8 tech back Member
    198
    The maf will read out of spec if egr is faulty so be careful with vcds readings
    post the full fault code with ambient readings as shown with vcds
    i would suggest the fault lies with n18/n213 valve body or the egr cooler change over vacuum unit
  8. rickyquicky
    rickyquicky Member
    342
    Thanks for the reply, I didnt use vag-com, (I dont have it or access to it) I used a friends 'snap on' diagnostics machine.
    The fault came up as a number and 'EGR insufficient flow'.
    My mate suggested it could in actual fact be the MAF at fault, but reading on the scanner as an EGR fault. This is what im questioning - is it true that a faulty MAF could give out an EGR insufficient flow fault code?
  9. a8 tech back
    a8 tech back Member
    198
    in theory yes but experience tells me its unlikely the cause
    you either have a lot of carbon build in the egr or a vacuum leak within n18/n213
    problem with this fault type is it will take time to reoccur as it will be sporadic and at a certain egr operation the flow is insufficient
    its a case of replacement of the suggested components providing there is no blockage
    good luck
  10. rickyquicky
    rickyquicky Member
    342
    Appreciate the help, thanks mate :thumbsup:
  11. rickyquicky
    rickyquicky Member
    342
    Update:
    I replaced the MAF sensor, and cleared the fault code...2 days later the engine management light comes on again with the same 'EGR insufficient flow fault'.
    Seeing as I had a new EGR about a year ago, what parts should I be looking at now? Im not familiar with n18/n213...what do these codes mean?
  12. NHN
    29,284
    1,695
    I have a fully working solenoid valve block for sale if you want to try this next.
  13. navnayyar
    navnayyar Member
    756
    I had insuffiecient flow after cleaning out my egr and manifold. I deleted the egr and never had a problem since
  14. rickyquicky
    rickyquicky Member
    342
    How much?
