EGR fault and DPF blocked
Discussion in 'A3/S3/Sportback (8P Chassis)' started by basssound, Dec 17, 2011.
  1. basssound
    basssound Member
    Dec 1, 2010
    203
    10
    Well last night the EML come on and then this morning the DPF warning came on.
    I used a scanner and checked the fault codes, there's only one fault.
    P0404 - Exhaust Gas Recirculation circuit range/performance
    Now obviously because of this EGR fault the DPF won't regenerate :/
    Anyone got any information or help, i'm reluctant to spend £200 for the EGR valve if it turns out the blocked DPF could be the cause?
  2. Advert Guest Advertisement
  3. mike foster
    mike foster Fossie
    Jan 16, 2010
    3,967
    You're sure you have a dpf ? Presumably you have a 170 ?
  4. basssound
    basssound Member
    Dec 1, 2010
    203
    10
    Yeah it's a 2.0 TDI 170
    Engine code is BMN, i'm a diesel mechanic for merc benz but I do know that a blocked DPF can cause EGR issues and vice versa ;)
  5. mike foster
    mike foster Fossie
    Jan 16, 2010
    3,967
    If you're a merc mechanic then you will know that VCDS is the usual diagnostic tool for VAG faults. Ross-Tech fault categories do not recognise that code but this may be helpful :- 16787/P0403/001027 - Ross-Tech Wiki
  6. basssound
    basssound Member
    Dec 1, 2010
    203
    10
    The P0404 is a recognised code for diesel engines with electronic EGR valves, I must admit I did use a MAC tools scanner
    but i'll have access to VCDS on Monday. I keep meaning to buy VCDS but I never seem to get round to doing it.
  7. basssound
    basssound Member
    Dec 1, 2010
    203
    10
    Anyone got the Audi instructions for checking the EGR feed, earth and reference signals?
  8. basssound
    basssound Member
    Dec 1, 2010
    203
    10
    I have removed the EGR valve and stripped it down to find the actual trumpet has snapped off the adjuster fork.
    A picture in a bit will show what I mean but this does mean I need a new EGR valve :(
    Stampie likes this.
  9. basssound
    basssound Member
    Dec 1, 2010
    203
    10
    Here is a picture of the mechanism inside the black plastic housing, as you can see the 'T' bar has snapped off, the round disc is the top hat.
    I have removed the disc and welded the 'T' bar back onto the trumpet which controls the amount of exhaust gas allowed through.
  10. Sidhu88
    Sidhu88 Active Member
    Jan 31, 2012
    809
    76
    not thread hijacking but i have a weird problem with the dpf not regenerating, whereabouts are u based?
