Egr delete ?
motfree Jan 18, 2011
  1. motfree
    motfree Member
    464
    Fitting an agu to my s3 but there's no where to plug the Egr valve into .. Been told that you can delete these ..
    If so what with and also will it affect the new motor in any way ??
  2. Imteyaz
    Imteyaz 6th Gear
    535
  3. motfree
    motfree Member
    464
    Not sure what I've got to do on that :-S looks like a ball ache lol thought it was literally just blank it off nothing else needed !!
    I'm not even sure what is gained from having this ??
    Or even what is gained from removing ??
  4. dany2k
    dany2k Member
    318
    hi mate,
    don't put put off: i did a egr delete on my previous mk4 golf: looks tricky but once you know what you're looking at you're fine. you gain the fact that your intake won't be getting clogged up with s***e and i experienced *slightly* better throttle response. then again, it was a GT TDi... never really thought about doing it on my 1.8 tqs... maybe it's just my desire to keep it standard though :)
  5. <tuffty/>
    21,899
    4,206
  6. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    Are you asking the same question as you did here?
    http://www.audi-sport.net/vb/a3-s3-...41-fitting-agu-lump-into-my-s3-need-help.html
    If so then as Tuffty says it's actually the SAI, take it you mean this
    Like I said on your other post. I've just done this with no problems.
    Also remove the SAI pump , and just used a 10w 470ohm restistor from Maplins 69p in the contector so the ECU doesn't throw up a fault code.
  7. Don's A3 TTu
    Don's A3 TTu Member
    317
    this looks like a good idea will this remove my secondary air pump cos i have a fault code on it ?
  8. Don's A3 TTu
    Don's A3 TTu Member
    317
    can i use these resistors for the evap canistor (air con) and air bag wiring to remove the fault codes?
  9. beachbuggy
    1,931
    202
    Evap canistor you could as it requires a current to flow in order for ecu not to register. Air bag not sure as think it's a switch circuit so may just need shorting like the brake pad sensor etc
  10. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    WTF?? Why would you do this??
  11. Don's A3 TTu
    Don's A3 TTu Member
    317
    because ive stripped them out so i know they dont work coz theyre not there!!!
  12. Welly
    10,696
    130
    Ohhhhhhhhhhh. Lol. I wouldn't have thought so mate to be fair, N75 is what I generally use.
  13. Don's A3 TTu
    Don's A3 TTu Member
    317
    N75???
  14. Welly
    10,696
    130
    lol, I have replaced several sensors with old duff N75 valves... Thats a pretty universal plug on the 1.8T engine.
  15. Don's A3 TTu
    Don's A3 TTu Member
    317
    so where would i get knackered ones from then?
  16. Welly
    10,696
    130
    Have a wanderround a local scrapper dude. Any N75 valve will do.... from any VAG varient as long as it's the same plug.
