EGR delete on PD170
Brodster Aug 23, 2012
  1. Brodster
    Brodster Well-Known Member Team Ibis Audi S4 Audi Avant Owner Group
    3,548
    886
    Morning guys. A quick one for the diesel tuners. A previous customer of mine wants to get the EGR delete mod but is it best to just blank it off or completely remove it. I've only ever seen it on a Fabia vRS that I mapped and never on an Audi. I would of thought it better to remove it completely and fit the delete kit then remap it. And how easy is it to do?
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,164
    1,123
    Don't the newer diesels throw up a error when removing the EGR?
    I assume you are able to remove the error via a map?
    Removing or deleting does the same thing really.
    They both stop the gasses from going back in.
    just doing the blanking plate is easier but removing it fully does make it look better and neatens up the engine bay
  3. Brodster
    3,548
    886
    Yeah it throws up an error code but thats easily mapped out as its just an update to his Stage 1 I did for him. Was just needing to know if its easier to blank it or remove it completely and if anyone has done the mod on here. Its the older PD170 on a '56 plate not the CR170 so I dont know if its any different
  4. ScottD3
    15,164
    1,123
    I've done the mod on every diesel I've owned and a 140PD.
    It is easier to slip in a metal blank and walk away over removing the pipe work, blocking off both ends and blocking off other pipe work.
  5. Brodster
    3,548
    886
    You got any pics of how to do it and where to put in the blanking plate.
  6. ScottD3
    15,164
    1,123
    Only Pics I got are from my B5.
    This is what you are after for the PD engine.
    Remove the 2 Torxs and shove the blanking plate and 2 new gaskets (up to you but I would) in there.
    Brodster likes this.
  7. Brodster
    3,548
    886
    Nice one cheers for that Scott.
  8. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,271
    611
    Just blank it off, done loads.
    Rick
  9. Gazzago
    Gazzago Member
    61
    Once you blank it off do you know how much it would cost to get the eml mapped out? Guessing you can't do it via vcds?
    I've got a lovely map on my car from Awesome gti in Manchester would like to keep it :)
    Gary
  10. Rick @ Unicorn Motor Dev.
    1,271
    611
    Nope, can't do it with VCDS. You can't keep your map either i'm afriad :(
    Rick
  11. Brodster
    3,548
    886
    Yep Rick is correct. Whatever map you have it will have to be modified to incorporate the EGR delete code basically to tell the car its not in operation anymore so it doesnt flag up any warning lights and codes. If you want it done just go back to where you got the map and ask them to give you the upgrade to the map for the EGR delete. Your car in theory should drive the same with slightly more power as its been deleted.
  12. Gazzago
    Gazzago Member
    61
    Cheers guys will give them a ring and see how many pennies they want to do the egr map delete.
    Gary
  13. Rhyso
    Rhyso Well-Known Member
    1,526
    318
    I found the throttle response to be much sharper too; its a win win situation :)
  14. chris1988brown
    chris1988brown Member
    575
    Will the car still drive perfectly fine with it blanked off or removed until you map the engine management ligh out
  15. Rick @ Unicorn Motor Dev.
    1,271
    611
    It will go into limp mode after a few miles, so you will be down on power.
    Rick
  16. chris1988brown
    575
    So you'd have to do the mod at your chosen tuner
  17. martinivw
    martinivw :)
    455
    25
    strange that, i blocked mine off and drove with eml on for around 6 months with NO probs, delete pipe was removed and sold on, but now i have another one to fit and will also remove the egr cooler :)
  18. SHAKEY LFC
    SHAKEY LFC Member
    44
    if i was to do the egr delete what would i need?
  19. astradti16v
    astradti16v Member
    54
    Is the egr blanking recomended when doing a remap on these?
  20. Rick @ Unicorn Motor Dev.
    1,271
    611
    Blank off the EGR and remap :)
    Rick
