Egr Delete 2.0TDI BKD
boosta10 Jul 13, 2011
  1. boosta10
    boosta10 New Member
    Hi
    I've got hold of a roadsport egr delete kit from FR&R Tuning and just wondering the best place to put the blank.
    I assume it's best to remove all the pipes (the pipe between the egr valve and the egr cooler, and the pipe between the manifold and egr cooler) and put the supplied blank on at the exhaust manifold.
    This would leave the egr cooler not necessarily but ideally requiring another 2 blanks on both the inlet and the outlet.
    (I've noticed that this is how they do it on the TD5 Landrover Engines here)
    What are other peoples interpretations on this?
  2. navnayyar
    navnayyar Member
    756
    Best blank it on the egr cooler and remove the cooler to intake pipe. I also blocked it on the turbo manifold so nothing going into to the egr cooler too :)
  3. A1DEYB
    A1DEYB Well-Known Member
    1,682
    43
    Whats the benefits of doing this on the A3? Just to stop having to cleaning the thing out or any perfomance gains to be had? I know when i did my Astra SRI 150 it was done to stop the inlet manifold flaps from choking up and sticking (common VX fault).
  4. Mixey
    Mixey New Member
    Hey I'm new to this so bear with me , I've recently brought an a3 2.0 tdi sport 53 reg , I'm losing water !! I'm putting about 1 litre a day in to top it up I've been to a few local specialists & apparently a common fault on the a3 in 2003-04 modles the cylinder head is faulty " prouspous " Baisicly it warps ?? Any 1 know any thing about this ? Im looking around £1000 from audi for a new head + labour to fit very expensive considering I paid £3700 4 the car ? I was thinking would it b poss to get it refurb or a second hand 1 & do it that way changing the belt n gaskit etc whilst I'm there ??? Help please
    Mike
  5. asasprey
    asasprey Member
    125
    Nobody helps thread hijackers and nobody will do a headgasket while you wait. It would take at least a day with skimming etc. Best start a thread yourself mate.
  6. danb986
    danb986 In awe of VCDS Team Daytona
    520
    60
    :iagree:
    He's posted this in 3 different places that I've seen so far.
  7. chrisy t
    chrisy t Member
    132
    Ok, so what are the gains from having the egr blanked off?
  8. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    EGR DELETE KIT IS A WASTE OF MONEY AS YOU CAN JUST FIT A BLANKING PLATE AND REMAP JOB DONE.
  9. TimG
    TimG Active Member
    942
    45
    I would also like to know why its done?
  10. nokia_aid
    nokia_aid Member
    47
    why fit a blanking plate,just take the vacume hose of the egr and then it wont open any more,job done
  11. cata_adc
    cata_adc Member
    122
    20
    What vacuum mate ? On the 8P models it's not operated by a vacum it's electronic controled
    The easyest way is with the blanking plate & remap
  12. MarkTweedley
    MarkTweedley Member
    144
    I already have a REVO remap so how would this affect me blanking off the EGR and where do I get the blanking plates?
  13. martinivw
    martinivw :)
    442
    24
    blanking plates available on ebay for around a fiver,
  14. martinivw
    martinivw :)
    442
    24
    vacum hose is attached to the diaphram on the lefthand side of the egr, remove the hose and block it off with a screw,
    pd engines do have a vacum, i dont know if the cr engines are any different?
  15. MarkTweedley
    MarkTweedley Member
    144
    Cheers dude. Found one for £2.99, bought and paid for now!
    Is it best to clean out the egr even when blocking it off and will it throw up a code?
  16. cata_adc
    cata_adc Member
    122
    20
    You are wrong not all the PD models are the same
    Mine looks like this : EGR Valve | Meat and Doria
    Like i said earlyer no vacum controled, it is electronic.
    If you have a bkd engine it is with vacum ;)
  17. martinivw
    martinivw :)
    442
    24
    My appoligies, as thread title is Egr Delete 2.0 TDI BKD, I thought that's what we were talking about! Current bmm diesels have
    electronic EGR's , I should have put pd BKD !!! :(
  18. cata_adc
    cata_adc Member
    122
    20
    No need to appologies mate.
    You are right the thread title was for the BKD engines.
    Best regards
  19. TimG
    TimG Active Member
    942
    45
    I would still love to know WHY people do this mod! Could someone kindly explain?
  20. cata_adc
    cata_adc Member
    122
    20
    When I have done stage 2 remap with the dpf off I had a problem with the egr.
    Something like a loss of power in 3rd and 4th gear at 1900-2000 rpm.
    Everything was checked , nothing wrong. After a log with vcds I saw that the problem was with the egr.
    The problem was sorted only with egr off.
    The engines runs more clean without the exhaust gas recirculation valve ;)
  21. MarkTweedley
    MarkTweedley Member
    144
    So with mine already having REVO can I just fit the blanking plate and job done. Any help appreciated. Thanks
  22. MarkTweedley
    MarkTweedley Member
    144
    Well got the blanking plate now. Looking to fit over weekend. Any guides on best way to do this? i.e. Someone make it easy for me! Ha!
    And as per previous posts - Will this throw up any codes and as I already have REVO will this need anything doing?
  23. martinivw
    martinivw :)
    442
    24
    Yes you will get the engine management light, speak to your mapper and ask them if they can modify your map to dissable the egr for you, then they will have to map the management light out as well,
    fitting the blanking plate is real easy, should be no problem :)
  24. MarkTweedley
    MarkTweedley Member
    144
    Cheers Martin. I assume other than needing my mapper to get rid of the light nd disable the egr will I be ok to just fit the blanking plate initially with no problems?
  25. martinivw
    martinivw :)
    442
    24
    yes, your engine should perform as normal.Before mine was fitted the intake manifold, throttle body and egr were removed and i cleaned them out with petrol before re assembly with egr delete pipe and blanks in place although the management light might piss u off if you dont get it mapped out,
    good luck :)
  26. MarkTweedley
    MarkTweedley Member
    144
    Cheers Martin.
  27. ~RS~
    ~RS~ Active Member
    1,466
    22
    How easy is it to fit an EGR blanking plate on a BKD?
    My EGR is supposedly stuffed.... As I'm fitting a hybrid I guess this mod would also be wise and save on buying a new EGR?
    From what I read this will not adversely effect any other parts on the car, is that corrcect...
  28. Beans
    Beans Member
    81
    Surely this would stuff up the emission test during the MOT?
    I'm assuming the benefit is to stop exhaust gasses diluting fresh air, hence higher performance (lower air temp, more oxygen rich etc).
  29. ~RS~
    ~RS~ Active Member
    1,466
    22
    Hmmmm.... Good point mate, but they're are lots of people with this mod sure all of them can't be failing MOT's.... or maybe the plate is removed before MOT :eyebrows:
  30. pioneer181
    pioneer181 Torque talks
    61
    Diesels don't have to pass an emissions text for an MOT, only a smoke test.
  31. dex140
    dex140 Member
    223
    Blanked mine this wekend! All you need is a plate and a 6mm allen key (think it was 6mm) and possibly two new gaskets. it has thrown a eml up on mine but the car runs noticably smoother!
  32. ~RS~
    ~RS~ Active Member
    1,466
    22
    Cheers pioneer181,
    I'd read that the EGR delete was fine for MOT but couldn't quite remember why.
    I've also just read that there are blanking plates with a 5mm gap that allow the EGR to still be operational, but the function is reduced dramatically by using VAG.COM to turn it down
    Hi Dex cheers for your post mate, mine is supposedly leaking from oil vapor build up whatever that means... I'm told oil doesn't actually flow to the EGR but it is in the air that does and is causing this leak on mine. I asked if the diaphragm was gone as I read this happens if they're leaking oil and was told no.
  33. dex140
    dex140 Member
    223
    when i fitted i also ran a tin of egr cleaner through it (this has has both good and bad reviews) so i took the intercooler pipe off which was very oily, like you said this will be from oil vapour!
    Only issue is i only had one gasket for the blan which i put on the egr side, when i get round to it im gonna put one one the other side of the blank to ensure no exhaust gas leaks int engine bay!
    I have another egr blanking plate that i think im gonna try and drill a 5mm hole in to allow some to pass through and hopefully get rid of the eml!
  34. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,253
    586
    Blanking the EGR will give smoother running and does not effect the MOT or smoke test in anyway. You need to have the ECU remapped in order to have it done or it will throw a code. We usually do it in conjunction with DPF removal.
    Rick
  35. dex140
    dex140 Member
    223
    Rick,
    Considering upgrading my 140bhp to the 170bhp, what figures would i be expecting with and egr and DPF delete and remap? (sorry for the mini hijak)
  36. Rick @ Unicorn Motor Dev.
    1,253
    586
    Hi dex, keeping the boost down to maintain turbo reliability, you are typically looking at around 200-210bhp.
    Rick
  37. dex140
    dex140 Member
    223
    Nice ....defo something i will be looking into!
  38. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    Seeing as noone has answered fully, EGR stands for "Exhaust Gas Rescirculation" and by blanking it off stops exhaust gases being put back into the combustion chamber, which isnt good for performance, only environment reasons, also sends a bit more exhaust gas through the turbo on the occasion, bare in mind that the EGR valve isnt always fed gas from the exhaust, its only on irregular occasions. Best times are motorway speeds.
  39. dex140
    dex140 Member
    223
    What do you mean by 'also sends a bit more exhaust gas through the turbo on occasion'?
  40. Djwoody
    Djwoody Member
    480
    21
    Sorry to resurrect this post.
    I'm going to blank my EGR off with a plate and then get the code mapped out.
    My question is, should I clean the EGR out at the same time or just leave it crudded up?
    If I should clean it, how is this done? Just by squirting EGR cleaner straight into it?
    Chris
