EGR cleaning
choimaloy Jan 6, 2011
  1. choimaloy
    choimaloy Member
    111
    I'm thinking of cleaning my egr on my 1.9 tdi do you guys have any advice on what to do and use for cleaning,car got 140k on it and the EGR is leaking a bit,is it worth buying a new one or just clean it.
  2. deanski
    deanski wax on, wax off
    369
    clean it and failing that blank it. IMO they arent worth replacing. they're a stupid idea and expensive to replace. all IMO of course lol.
  3. simon.m
    simon.m Active Member
    2,747
    is it hard to blank it off ? dose the car not need it then ? last ? what would the benafit be if its blanked off ?
  4. Funkyfin2000
    Funkyfin2000 Member
    489
    I could do with these answers too!
  5. Yappy
    Yappy A4 b6 TDI V6 Quattro Sport
    150
    No the car doesn't need it
    The car will run slightly cooler in as much as act (air charge temp)
    And in turn will give not alot but a tiny bhp gain If I'm correct and it also frees up some space under the bonnet
    And if your ok with some spanners it's fairly easy you will need two blanking plates and a bolt for the little vacuum hose then job done that's as long as it's a manual one if it has an electrical connection on it then I'm not sure if the car relies on it or not but my a4 2.5 v6 tdi is egr deleted and is fine
    Hope this helps fella:yum:
  6. Funkyfin2000
    Funkyfin2000 Member
    489
  7. Yappy
    150
    Nope I didnt have to mate if you look at it and see if the egr valve has wires going to it you prob will have to delete it of the software too
    And yeah you will need 2 of the blanking plates and any gaskets to
    Good luck mate:sm4:
  8. choimaloy
    choimaloy Member
    111
    what would you use to clean it,would i need to get new gaskets to?
  9. simon.m
    2,747
    you can buy an egr cleaner from any good car shop for a few pounds and id say yes to a new gaskets mate if your taking it off best to put new ones on
  10. ADC74
    ADC74 Member
    155
    I always use carb cleaner, works a treat :yum:
  11. simon.m
    2,747
    just make sure its for tdis then ;-)
  12. ADC74
    ADC74 Member
    155
    Didn't realise it made a difference, but then again I'm a derv virgin :blush:
    Thanks for that Simon :thumbsup:
  13. Funkyfin2000
    Funkyfin2000 Member
    489
    Does anyone have any infor about blanking the EGR on a 1.9tdi can't find any anywhere :(
  14. way318
    way318 Active Member
    296
    29
    Try looking on tdisport forum, there will be info on there about EGR blanking etc.
    I am going to do mine when the weather is a bit better. I've already bought the blanking plates and they only cost £4.50 for 2 off ebay. I can give you the guys email address if you want it?
    On the 1.9 TDi (AWX engine code) to get the EGR Valve off to clean it you also need to remove the exhaust manifold so you can access all the bolts which secure the EGR Valve to the manifold.
    My plan is to blank it off first, then when its alot warmer do the cleaning bit. To blank it off all you need to do is remove the pipe that connects between the EGR Valve & the exhaust manifold and then put a blanking plates we the pipe used to bolt to, one on the back of the EGR valve and one on the manifold.
    Don't forget this info is for the AWX engine code, so may not be correct for your's. But I think the principle is the same.
    The EGR will leak and thats normal, my A4 is on 152K and is doing the same.
  15. choimaloy
    choimaloy Member
    111
    thanx mines a AWX engine code so i didnt know that,is that easy to remove?
  16. way318
    296
    29
    In principle, yes. But will let you know when i do it.
    If you do your's before I manage to do mine, let me know how you get on and vice versa.
  17. Avant4me
    Avant4me The're Graphite not black!!
    257
    Exhaust removal seems a pain in the ass, but need to do mine, as it smokes a lot when i boot it
  18. braf89
    braf89 New Member
    17
    I dont think theres any need for the blanking plates. A audi mechanic blanked my girlfriends awx and all he did was put a ball bearing in the vaccum hose and clear it on the computer. I have it done for about a month now and its perfect no problems since.
