EGR Blanking plate 2.0 TDI. Any improvements?
Wats-on May 21, 2012
  1. Wats-on
    Wats-on New Member
    22
    Hello there!
    I recently removed and cleaned up my EGR as it was completely covered and also noticed the inlet manifold was pretty thick too. I decided to try a blanking plate for the EGR to see if it made it run any better.
    I bought it off of eBay for £2.99, took 2 minutes to fit...but i haven't really noticed any difference, it seemed to idle a little better but apart from that nothing. It also caused the engine management light to come on.
    Just wondering has anyone else tried it and actually found it has improved anything?
    Jack
  2. dex140
    dex140 Member
    223
    I fitted one on sat! Seems to idle loads better, im currently monitoring mpg to see if there is any improovement which there is meant to be!
  3. Wats-on
    Wats-on New Member
    22
    Yer I noticed the idle, and now you mention it, my mpg was running high 40's mid 50's most of the time. Has it made your engine management light come on? I have taken mine off again the engine management light has gone off. Might put it on again and leave it for a bit longer.
  4. A1DEYB
    A1DEYB Well-Known Member
    1,682
    43
    The engine management light will stay on until you have the car remapped and have the EGR valve deleted out of the new map.
    If you continue to run your standard map then the EGR valve will always bring on the engine management light and you can't turn it off in VCDS as far as I'm aware, I've looked into it before.
  5. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,250
    582
    It runs smoother because the engine isn't getting dirty sooty air fed into it!
    If you do a blank, then it's good to decoke the inlet too, you will be suprised how dirty it is. The car needs remapping in order to switch off the management loght
    Rick
    tdi-man likes this.
  6. Wats-on
    Wats-on New Member
    22
    Thanks for the help and advice!! Seem to be finding more problems with my car as the mileage increases, on 130k now!
  7. max69vk
    max69vk Active Member
    862
    57
    Seat do a 'reduced' size EGR gasket which is meant for the MK3 Seat Ibiza for about £5 which fits, try using one of those & it will restrict the EGR but not totally close it so the engine will run better but not show any warning lights on the dash
  8. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,072
    60
    I take it you got it from Seat dealership?
  9. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    028 131 547 B from your local vag parts desk
    SDHA4SLine likes this.
  10. max69vk
    862
    57
    It's a standard part I believe the code is : 028131547B , I havent fitted mine yet as the car has other issues to be dealt with first, but its a popular mod on the Seat forums & for around a fiver its worth a look. The only thing that may come up is with a diagnostic scan the car will show as having an EGR flow rate not being correct, however as we're the ones restricting the flow it's nothing to worry about, no lights should be popping up on the dash though.
  11. max69vk
    862
    57
    Beaten to the punch! :)
  12. A1DEYB
    1,682
    43
    What's the benefit of doing this?
    Will it make the 2.0L engine a tad more refined on idle or is it wishful thinking?
  13. max69vk
    862
    57
    Yep. it improves the idle massively.
  14. A1DEYB
    1,682
    43
    Lol are you being sarcastic or serious?
  15. dex140
    dex140 Member
    223
    No defo imprrove the idle a great deal.... been running mine blanked for two weeks now!
  16. A1DEYB
    1,682
    43
    Think i'll have a punt at a fiver, do seat dealers stock them or are they ordered in?
  17. Rick @ Unicorn Motor Dev.
    1,250
    582
    It does improve the idle, yes.
  18. max69vk
    862
    57
    Should be a stock item, if they dont have it in it usually takes 24 hrs or overnight :)
  19. Ste_Nova
    1,223
    47
    audi have them too
  20. A1DEYB
    1,682
    43
    You got a part number please?
  21. Ste_Nova
    1,223
    47
    up there ^^^^ with the pic
  22. A1DEYB
    1,682
    43
    Of course, whata knobhead lol.
  23. Mindak
    Mindak Active Member
    787
    130
    43
    Old thread revival! Lol
    Anybody been running one of these reduced gaskets?
  24. Mindak
    787
    130
    43
    Anybody?
  25. Red s line
    Red s line Member
    99
    i too would like to know how the reduced plate performs ??
  26. A19quattro
    A19quattro Active Member
    601
    91
    Me too, anyone got pictures of fitting, where it goes etc?
  27. Rideen
    Rideen Sport Mode Audi A3
    538
    75
    Offtopic: Seeing you all guys talking about 40-50MPG makes me said.. I average around 35 on my 2.0. :(
  28. Lukeyb
    Lukeyb Active Member
    397
    53
    Delete and code out is the way forward we have 1 delete and 1 stock, mines messed about with, swmbo is stock, the difference is blindingly obvious hers shakes like a sh@tting dog at idle
    Taff2015 likes this.
