EGR blanked off now got EML on.
pauldazzle Mar 9, 2012
  1. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    What car is that gasket off then......thought they were all the same.
  2. Funkyfin2000
    Funkyfin2000 Member
    489
    Yup more detail needed please jbs!
  3. wesmaster
    wesmaster Member
    300
    20
    I offer the service of EGR deletion via a remap as well as DPF deletion (for track use only ;-)
    Maps are written by Mobile ECU remaps.
    Cheers.
    Wesmaster
  4. Mike.M
    2,510
    170
  5. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,282
    618
    That is ourselves, and yes we can do it no problem! Noone elses map, it is written by myself. Send me a PM and i can give you a call and can explain all :)
    Rick
  6. scottshere
    scottshere Member
    369
    17
  7. Funkyfin2000
    Funkyfin2000 Member
    489
    Yup let us know how you get on.
    How much was the part?
    Rich
  8. Funkyfin2000
    Funkyfin2000 Member
    489
    ahhh about £2! LOL!
    I reckon I'l try this!
  9. Funkyfin2000
    Funkyfin2000 Member
    489
    PS did you order two? ONE for each side of the EGR?
  10. Mike.M
    2,510
    170
    Just ordered one from TPS and will be here tomorrow (Tuesday) will fit that eve and see how it goes.
    It replaces the gasket closest to the EGR valve. You only need one as if you add another but at the manifold end there is a good chance of collecting sludgy water/oil in the pipe work as you would be making a cooling chamber due to the smaller entry and exit of the pipe if that makes sense.
  11. Mike.M
    2,510
    170
    Got the gasket today and have fitted it.
    Decided to take the egr off then fit the gasket as it was awkward to access the small feed pipe bolts to fit the gasket, but in all the job took about 30min to do it all so not bad.
    Not driven the car yet but will see in the morning and let you know, but suspect it may be a couple of drives while the ECU adapts
  12. scottshere
    scottshere Member
    369
    17
    Nice...
    Have you still plugged the top pipe with something?
  13. Mike.M
    2,510
    170
    All connected as normal, but the new gasket will reduce significaly the exhaust gases flowing through the EGR and keep the engine light off as mine is the fussy 2004 variant where unplugging hose etc like the older models does not work the same.
  14. marktdisport
    marktdisport Active Member
    1,195
    15
    This is interesting !! Just hop it works
  15. Mike.M
    2,510
    170
    Drove car to work and all seems fine and was quite responsive with no warning light like when I disconnected the EGR. The hole in the gasket is much smaller at 9mm in diameter.
    I did notice a significant drop in smoke when the car was started from cold and when pulling away hard, compared to before the gasket change
    I will give it a few more days of driving but it seems to be working fine so far.
  16. pauldazzle
    pauldazzle Well-Known Member
    1,192
    95
    I did mine today, & no EML yet.
  17. Mike.M
    2,510
    170
    Still all ok here and no EML also. There is def a reduction in smoke and it just runs a lot better/smoother too for sure.
  18. Funkyfin2000
    Funkyfin2000 Member
    489
    Excellent, cheers guys, will get one for mine...2004 one....
    Cracking feedback guys!
  19. Mike.M
    2,510
    170
    Not bad for a couple of quid.
  20. pauldazzle
    1,192
    95
    Still no EML & I think the engine feels a bit smoother & more responsive.:rock:
  21. Funkyfin2000
    Funkyfin2000 Member
    489
    FAB!
  22. scottshere
    scottshere Member
    369
    17
    Im struggling to find where to order this from online :(
  23. Mike.M
    2,510
    170
    I got mine from my local VW TPS otherwise get it from the dealer.
  24. JBS Sales
    JBS Sales Member
    395
    Glad to hear you are all finding the small hole gasket works, seems to be a good middle ground for reducing issues without paying for an expensive delete pipe.
  25. Funkyfin2000
    Funkyfin2000 Member
    489
    ordered mine £2.12 + VAT.... will wait and see and update you!
