EGR blanked off now got EML on.
pauldazzle Mar 9, 2012
  1. pauldazzle
    pauldazzle Well-Known Member
    1,191
    95
    Blanked my EGR off today, but after a couple of driving cycles the EML has come on. (19586 EGR System Regulation Range Exceeded)
    Just wondering if I can change any adaptation settings to overcome this?
  2. pink.teg
    pink.teg Member
    170
    Hi Paul
    im in Cardiff area too
    we must meet up some time
    and talk mods !!!!
    Alan
  3. pauldazzle
    1,191
    95
    Yeah, nothing much seems to happen ASN meet wise in Sth Wales.
  4. NHN
    29,521
    1,765
    You need this coded out by a proper tuner.
  5. blucoop
    blucoop Member
    85
    I have exactly same problem yesterday, light came on after couple of drives now wont go off.
  6. quattrojames
    14,060
    583
    Have you spoken to CMD? I'm sure he has mentioned meets in that area before.
  7. mattyboyc
    mattyboyc B6 Veteran Audi A4 Audi Avant Owner Group TDi
    1,995
    217
    This is why I used the Allard EGR Delete kit as you remove the EGR vaulve, hence no more EGR problems and no engine management lights.
  8. NHN
    29,521
    1,765
    Really, even with egr removed, you still need it coded out afaik, you saying you didnt code yours out?
  9. mattyboyc
    1,995
    217
    No nothing, been done over a couple of months now and no problems, I had one issue where the ESP and glowlight lights came on and the car lost all power but a scan showed a throttle problem, removed and cleaned plug on throttle pedal and all been ok since.
  10. NHN
    29,521
    1,765
    I wonder if its different on the 1.9 B6, as I always knew they had to be coded out, but alas every days a school day.
  11. mattyboyc
    1,995
    217
    Must be, I would have thought I would have had EML issues by now if I was going to.
  12. pauldazzle
    1,191
    95
    Just changed the EGR duty cycle, & so far so good no EML today.
  13. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    I've blanked off my egr with no issues or eml I have a 2002 1.9tdi
  14. pauldazzle
    1,191
    95
    EML came back on today after 4 driving cycles:banghead:
    Oh well looks like I'll be taking the blanking plate off. Annoying as the car definitely feels sharper, & more responsive with the blanking plate on. Even the wife commented last night that the car felt powerful, & she doesn't know I'd changed anything!
  15. mikeh126
    mikeh126 Member
    152
    Same here - EGR blanking plate fitted 6 months ago with no issues, and no EML. Deffo better and crisper performance without it.
    I was told by a mate (who also happens to be an auto electrician) that only the later models with an electronic sensor fitted would bring the EML light on. Mine only has the vacuum pipe fitted - so I fitted the blanking plate.
    But, if the OP's 2002 model brings the EML on, maybe he's wrong? Confused.com!!
  16. hades-
    9,481
    646
    Iv noticed in a few early B6 that the light dont come on
    but as above if it does come on it needs writeing out cant be done with VCDS
  17. scottshere
    scottshere Member
    372
    My EML came on when i blanked mine off...
    Still on now as i dont plan on taking the blank out
  18. NHN
    29,521
    1,765
    Only way the ecu would know there was an issue is if its monitoring the egr flap/flow via a sender, so maybe some earlier cars didnt have this inline & it as just a dumb valve as such, who knows.
  19. pauldazzle
    1,191
    95
    My car is a late 2003. I guess it must have a flow sensor. Reducing the EGR cycle seems to have extended the time before the EML comes, but obviously the ECU still doesn't like the EGR being blanked off.
  20. blucoop
    blucoop Member
    85
    so if the light cant be switched off/written out with vcds who would be able to this?? my car is much better and chucks out much less smoke since i blanked mine, so i dont really want to unblank it!!!
  21. hades-
    9,481
    646
    any tuner that does maps
  22. NHN
    29,521
    1,765
    I'd say any tuner that writes maps, as allot of tuners are just resellers of a mapping ecosystem as such, I found not allot can actually write a map & thus couldnt actually do an egr write out as such.
  23. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,271
    611
    Hi all,
    We are able to code out the EGR.
    Thanks, Rick
  24. NHN
    29,521
    1,765
    Price?
  25. Rick @ Unicorn Motor Dev.
    1,271
    611
    Depends on the ECU, but if it's from a B6 it would be £95 or free as part of a remap.
    Rick
  26. scottshere
    scottshere Member
    372
    How much for a custom remap (rolling road) on B6 1.9tdi 130 ?
  27. Rick @ Unicorn Motor Dev.
    1,271
    611
    Hi Scott,
    is your car still on standard injectors?
    Rick
  28. scottshere
    scottshere Member
    372
    Hi,
    Yes its all standard
  29. Heathie
    Heathie Member
    Hi, I fitted a egr bypass valve to my rover 75 tdi with noe problems at all, i have just ordered an Allard EGR bypass kit for my 1999 Audi A3 1.9 tdi and will be fitting it shortly when it arrives
  30. Funkyfin2000
    Funkyfin2000 Member
    489
  31. pauldazzle
    1,191
    95
    That's odd mapping out the EGR is pretty standard stuff for most tuners!
  32. NHN
    29,521
    1,765
    Not if they're a virtual/file tuner, then they're stuck to what there file suppliers can do, you need a real tuner who can actually write a map themselves to be able to do it all at same time, in most circumstances.
  33. demus
    demus Fire in the hole..
    355
    19
    I'm sure some TDI's use the MAF sensor to monitor the EGR, as the EGR opens and lets in the exhaust, the MAF reading should drop accordingly... don't quote me on it though
  34. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    My 2004 had the EGR warning light come on after a few cycles when I disconnected and plugged up hose.......i reconnected everything and cleared the code and back to normal.
    I may disconnect again and live with the warning light until MOT time.
  35. Funkyfin2000
    Funkyfin2000 Member
    489
    I believe Viezu Technologies : Car Tuning, Performance Engine Tuning, ECU Remapping / ECU Remaps are a proper coder.
    My standard map was sent to them to be adjusted and mapped bespokely.....
    The problem was specifically with the AVF engine code it seemed as been fine for other 1.9 tdi said my garage....
    I have offered to put my car forward as a test bed so they can try some live mapping on it to get rid of EGR.....shall see what they say :)
    Rich
  36. Mike.M
    2,510
    170
    Cool......mine is the same engine code
  37. Funkyfin2000
    Funkyfin2000 Member
    489
    sadly they are not interested, tried but the car is too old for them to want to do anything with it.
    I see mentioned above, that someone in Stockport can take it out for £95, is that with someone elses map? If not, the EGR is going back on!
  38. 666markyboy
    666markyboy Well-Known Member
    1,228
    55
    I think it's more to do with the age of the car rather than the engine code.... i have an AVF in a 2002 car and dissabled the EGR by unplugging the pipes and blanking them off,,,, the Golf Tee method this means the valve is closed in it's default position but never gets opened .... i've never had a fault code in 12 months of doing it
  39. JBS Sales
    JBS Sales Member
    395
    Have you guys tried the small hole EGR gasket, limits the flow through the EGR but doesn’t completely stop it meaning you shouldn’t get the EML coming on.
    Having sold a number recently the owners of said vehicles have noticed a marked improvement in drivability and issues they were experiencing without the cost of an EGR blanking plate, delete kit or software change.
  40. pauldazzle
    1,191
    95
    Couldn't find anything on the JBS website. Can you give more details i.e. fitting & price?
