  1. Tim Woodman
    Tim Woodman New Member
    10
    Hi, as soon as it stops raining I'm going to install two egr blank plates I recently purchased. Egr not responding well in this weather! Think its the operating solenoid. .
    Can someone deffinitively tell me if I need to disconnect any vac pipes from the egr if I fit the plates or am I just good to go?
    Presumably the egr valve still moves if vac pipes are still connected.
    Quite hopeful I wont get eml as this is a 2001 model, AWX engine
    Thanks Tim
  2. Gazwould
    Gazwould Well-Known Member
    5,130
    2,094
    You wont get an eml on a 2001.
    Disconnect vac pipe and block with a small bolt.
    As far as I know only 1 blank is required between exhaust manifold and egr feed pipe.
  3. Tim Woodman
    10
    Thanks for this, should I remove and plug the vac pipe to the top of the egr and the manifold flap below? Or just one of these?
  4. Jimmy TDI
    Jimmy TDI Pro Tinkerer Audi A4 Audi Avant Owner Group TDi
    1,320
    262
    Have a look at my build there is a how to for this, but I haven't removed the vac pipe ATM as I'm planing on replacing all my vac lines. You need a plate at either end, or you risk the s shaped pipe bursting under load.
  5. Jimmy TDI
    1,320
    262
    Just the pipe that controls the EGR valve.
  6. Gazwould
    5,130
    2,094
    On Jim's build thread he's totally removed the egr feed pipe, needing 2 blanks.
    I've kept mine in place and used 1 sloted slip in blank on the exhaust manifold bottom end.
  7. Tim Woodman
    10
    Great thanks for this, I read through the build very helpful
