EGR Blank dissapointment
Ian2012 Apr 24, 2013
  1. Ian2012
    Ian2012 Active Member
    473
    29
    Well here it is,blanking plates arrived today fitted them, and after about 20 mins of driving the engine management is on, have reset it but it's now back on again, plates to be removed tomorrow, bugger.
  2. southylad
    southylad Active Member
    544
    the light will come on you either put up with it and be satified you are not circuating old ****ty gasses through your engine or get the egr mapped out of the system so the light will not come on as i did when i got the car mapped only extra £30
  3. Ian2012
    473
    29
    mapping is on the agenda when funds allow, where did you get yours mapped??
  4. southylad
    544
    awesome gti , i deleted my egr long before the map its no problem
  5. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    Got mine mapped out for free when I had the remap done at Ecotech performance.
  6. duffy78
    duffy78 Member
    188
    Blacksmoke do a map for £45 that maps out the egr. Have a look on their website.
  7. Audi Doodah
    Audi Doodah Active Member
    377
    35
    Thumbs up for Blacksmoke if you don't mind the risk! Not all ECUs are listed so if you have to request one from Andrew then you will need to specify that you wish the EGR to be mapped out.
  8. Ian2012
    473
    29
    I have looked at Blacksmoke before but i haven't got the software to upload the file, i have vcds though
  9. Audi Doodah
    377
    35
  10. Ian2012
    473
    29
    Many thanks for the heads upon the previous posts made for interesting reading, i will grab myself lead seems to good to be true!
  11. Audi Doodah
    377
    35
    It is true and can't fault the map but be warned, it will find out a worn clutch/flywheel. Mine lasted 6 weeks but it was 147k old. A mate of mine who put me onto the site has had the same issue too
  12. Ian2012
    473
    29
    my clutch is on 139k, hmm now when i get paid...................
  13. Audi Doodah
    377
    35
    £787 for clutch, flywheel, bolts, slave cylinder, gearbox oil and labour 2 days ago for my 6 speed. A little cheaper if you have a 5 speed.
  14. Mollygoogle
    Mollygoogle Member
    241
    The EGR has been blanked on my 130 for the last 12000 miles without a light
  15. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    It depends on the age. I think very early a4's <2002 have no problems. Mine is a 2002 with the egr blanked also and no light, but I'm assuming the OP's is a bit newer?
  16. czm
    czm Member
    266
    19
    Sorry to be a complete n00b but whats the benefit of blanking the egr?
  17. Audi Doodah
    377
    35
    Your car breathes clean air only and no recycled soot from the exhaust.
  18. BRILLO
    BRILLO Member
    140
    picks up a bit better as well.
  19. Ian2012
    473
    29
    I would agree on pick up i have now put the pipe back on and cleared the code for now until i figure out what ia m doing the car is an 03
  20. crazy88
    4,939
    437
    Gotta be honest and say I didn't notice a bit of difference. However, I'd rather have clean air only in my engine than exhaust gases so I'm keeping it blanked.
  21. Mike_B
    Mike_B Active Member
    533
    47
    - - but pumps out soot into the environment - - causing asthma, cancer and general pollution?
  22. Audi Doodah
    377
    35
    Yeah, because cars with EGR valves are totally pollution free!?!?
    audilad9 likes this.
  23. BRILLO
    BRILLO Member
    140
    Mine has never smoked since I done it. And mot emissions were better than last year.
  24. crazy88
    4,939
    437
    Meh, I cycle to work everyday so I do my bit for the environment. Thanks for the lecture though. ;)
    Audi Doodah likes this.
  25. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    You buy restriction plates.
    It stops a lot of the gases but let's enough through to keep the sensor happy.
    The PD boys uses one cause they get the same errors.
  26. Steve220
    Steve220 Member
    234
    15
    when has soot ever caused cancer?
  27. BRILLO
    BRILLO Member
    140
    take it you could just drill an 8mm hole in the blanking plate then
  28. crazy88
    4,939
    437
    Possibly, but the blanking plates are usually quite thick and almost impossible to fit them on with the pipe too, whereas the restricting plates are much thinner, like the gasket.
  29. BRILLO
    BRILLO Member
    140
    Ah well. Just a thought.
  30. crazy88
    4,939
    437
    Actually, you've got more chance if you just fit 1. I think you'd still struggle, but with 1 blanking plate there's a slim chance.
    The restriction plate is fairly cheap too though. A lot of skoda drivers use them.
  31. deano1978
    deano1978 different gear
    713
    81
    i tried this on my 04 1.9.
    8mm hole in blanking plate,still brought light on :-(
    So got mine maped out.
  32. Mike_B
    533
    47
    BBC News - Diesel exhausts do cause cancer, says WHO
    Just saying - not too sure why you need to interpret that as a "lecture" - I'm as entitled to my opinion (supported by the evidence above) as you are. :)
    Then again, I run a nice clean petrol engine and the cat removes all the nasties - - -
    Mike.
  33. crazy88
    4,939
    437
    Seen as we're getting picky...it removes "all" the nasties? Like every single nasty? Or just a lot of them?
    And anyway, I was clearly joking, I wrote a winking smiley on the end. :) it's just hard to get tone across on this place. Sorry if I came across as a twat, I'm not one. Honest!
    Since I cycle a lot and hardly use my car it's a no brainer for me.
    NHN likes this.
  34. Mike_B
    533
    47
    Fair enough - not the carbon dioxide - - - then again, I quite like fizzy drinks - - -
    I noted the smiley - and added my own - -
    I agree about "tone" - it's interesting how pedantry / picky is acceptable if we're into "detailing" - but perhaps less so in discussing the accuracy of a forum conversation about exhaust emissions! Hey ho.
    Mike.
  35. crazy88
    4,939
    437
    Fizzy drinks...Pfft! They're terrible for the environment!
  36. Mike_B
    533
    47
    Fair enough - I'll buy a bottle of pure spring water instead - oh wait, that's a throw away bottle - but if I do throw it in the recycliing, then it can get made into things like Polartec or possibly loft insulation which helps save the planet - I know, I'll buy a nice reusable aluminium one - ahhh - but doesn't the production of aluminium produce masses of nasties - - - - - -
  37. Gaz!
    Gaz! Member
    159
    14
    Pfft, I've blanked the egr and put a straight pipe in place instead of the particulate filter. Little better performance, happy days.
    crazy88 likes this.
  38. audilad9
    audilad9 Member
    257
    If you just disconnect the vaccum pipe on top of EGR, this stops it working ie: no exhaust gases entering inlet.
    So I was told by Audi master technician not long after buying my car.
    I did it and blanked the hose with a bolt and never had any bother, no light on and no build up of soot in EGR or inlet.
    So I figured if you do this early enough in the cars life it prevents the problem occuring (I did it at 55k) or clean out manifold and EGR then do it.
    My car is an 04 AVF.
    I have since fitted EGR blanking plates and removed the flexi pipe. I also removed and cleaned out the inlet manifold and EGR, which were pretty clean, just for peace of mind realy.
    Whilst at it I also did the Mr muscle turbo vanes clean, preventitive maintenance I hope.
    Car goes realy well, think it does pick up better.
