EGR and anti shudder valve removed and cleaned. Coated!!
Wats-on Mar 24, 2012
  1. Wats-on
    Wats-on New Member
    22
    [​IMG]Hello,
    Well car has been running a little bit lumpy on idle and have been reading about the EGR valve getting blocked up.
    So today I removed the EGR and anti shudder valve which sits below it.
    The anti shudder valve was relatively clean but the EGR was completely coated in black carbon build up.
    Using brake and clutch cleaner along with compressed air, I cleaned both parts up and now the car is running a lot smoother on idle and when driving.
    It was a little fiddly getting the back allen key bolt out but perseverance paid off!
    Im also thinking about taking the inlet manifold off and blasting that through as when i put my fingers up inside it seemed quite thickly coated also!
    Just thought id put it out there in case anyone is having similar troubles!
    wallace78 likes this.
  2. Wats-on
    Wats-on New Member
    22
    Not sure if this picture has uploaded?
  3. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,266
    360
    yeah it has, good work
  4. Wats-on
    Wats-on New Member
    22
    Good stuff! theres one of the anti shudder valve after a clean too. [​IMG]
  5. Rab6880
    Rab6880 New Member
    Hi,
    my egr's needing replaced, I was just wondering how big a job it is.
    thanks Rab
  6. Wats-on
    Wats-on New Member
    22
    Hello, um pretty simple, just a few allen key bolts, which you can see as its right at the front of the engine bay. the only tricky one is at the back of it, but I don't think I was using the correct tool really, also need to unbolt the pipe that goes into the side of the EGR.
    Good luck
    Jack
