Eggy smell to climate control
gaznogaro2003 Nov 3, 2010
  1. gaznogaro2003
    gaznogaro2003 Member
    86
    Just started noticing yesterday that I have an Eggy smell coming from my climate control
    Only lasts for 2mins when it's first used from cold though
    Any ideas??
  2. talentwalsh
    talentwalsh Member
    139
    Do you use it often? The gas can become stagnant if not used for a while. A recharge of gas may be on order
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    No its not the gas, it is bacteria on the condenser.....you can try a disinfectant bomb at halfords about a tenner ....
    common problem if you dont use it regulary
  4. BASS 666
    BASS 666 BMW aye right dead on..
    463
    it can be both of the above mine was a dirty pollen filter.
  5. gaznogaro2003
    86
    Used every day guys!
    What do you think?
    It's due a service at audi soon do will get a new pollen fitted then
  6. s3dave
    10,110
    736
    If you can smell the gas you have a bigger problem and it would be empty within miniutes
  7. BASS 666
    463
    i think he meant a smelly system.
  8. gaznogaro2003
    86
    Not gas guys just a bit of a Eggy smell ;0(
  9. BASS 666
    463
    like i say, i changed my pollen filter and it went away so give it a try mate.
  10. gaznogaro2003
    86
    Didn't do it the morning strange......pollen filter going to be done on service end of this month
  11. djarchive
    djarchive Member
    275
    Anybody got a link to a pollen filter? Can it be easily changed?
  12. s3dave
    10,110
    736
    You need to take the scuttle panel off,
    wipers off and carefully unclip the scuttle panel, filter is on the passenger side....
  13. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    how much are pollen filters mine is starting to smell aswell. i need to open it up anyway as i have loads of leaves behind there
  14. DaveA3
    2,370
    15
  15. gaznogaro2003
    86
    I've got a sneaky idea that it's to do with my washer jets!
    Ive not sprayed my washer jets when I got in the car today until tonight!
    If I spray them as soon as the cars started and the climate control is blasting the windscreen the smell appears!
    No washer jets but climate control and it's fine!
  16. BASS 666
    463
    that would be really wierd cause they are not linked at all..i know you can smell the screen wash when you spray the window but you would need to be using some nasty stuff lol..
  17. gaznogaro2003
    86
    It's halfords best!!!!
    I'm going to empty it today and refill and see what happens!
  18. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Could be manky washer water. One of our cars at work smelt real bad of farts when you cleaned the windscreen...the washer fluid had gone off!!. Give it a fill up with warm water with some detol in it or something and then spray it all through before refilling as normal.
    My AC smelt by the way...new pollen filter cured it. Dead easy to fit and no need to remove wipers etc as there was a little flap on my scuttle that I could lift up to get to it etc.
  19. gaznogaro2003
    86
    Problem sorted!
    Flushed out twice with fairy liquid and its fine now!
    Might do again with something else soon that can remove the **** from inside as the fairy liquidf hasnt removed it all
