Eggy smell and engine management light
baz1 Aug 14, 2009
  1. baz1
    baz1 New Member
    23
    Hi guys,
    got a a3 3.2 v6 dsg. Engine management light has come on, revs are bouncing around on idle and getting a strong eggy smell from engine bay!
    Any ideas?
  2. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,218
    2,033
  3. baz1
    baz1 New Member
    23
    Why wud ther b an eggy smell??
  4. voorhees
    16,218
    2,033
    lack of water in the battery causing it or "The sulphur smell from the exhaust, is actually caused by running the engine/cat convertor slightly lean for long periods and then running under a rich condition (ie going up a hill under heavy load) This is when the sulphur smell (rotten egg) is produced.
    Under relatively lean conditions, the sulphur found in gasoline is converted to sulphur trioxide, then during the rich running condition the sulfur trioxide is converted into hydrogen sulphide (rotten egg smell) within the catalytic converter.
    Audi of America issued a service bulletin Group 24, #92-04 which detailed this problem. They list the cause as : the gasoline sulphur content and the characteristic of catalytic convertor to store sulphur compounds and release them during rich engine running conditions.
    Switching gasoline brands may help. The Oxygen sensor may also need to be replaced to correct a fuel injection mixture problem"
  5. voorhees
    16,218
    2,033
    or you have a flatulence problem your unaware of ?
  6. baz1
    baz1 New Member
    23
    Wats that? Thanks 4 ur help btw
  7. voorhees
    16,218
    2,033
    farting :)
  8. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,276
    165
    I had this last week. Lumpy at tickover but fine once reving. You need to get the fault code but mine was the lambda sensor. About £200 at Audi fitterd and tested.
  9. baz1
    baz1 New Member
    23
    i'm also getting a petrol smell and a whooshing noise everytime i press the accelerator. Is this safe to drive to the garage tomorrow?
  10. edition
    edition Active Member
    1,426
    The battery is in the boot!
  11. paddy
    5,276
    165
    Mine smelt of petrol at tickover as well....I drove it 20 miles to audi guildford no problem...
  12. voorhees
    16,218
    2,033
    so you are saying that if you never topped it up with water the smell of sulphur would magically disappear and not enter the cabin ?
  13. paddy
    5,276
    165
    Its not likely as it has a sealed lid to its compartment and is maintanance free anyway. Cant see how this would give him a lumpy tickover either..
    at the end of the day its guess work but can he drive it saftly to a garage........well i wouldnt put my head on the block :)
  14. Broken Byzan
    13,237
    465
    It's probably a faulty coil pack, causing an overrich situation, causing the cat to spew the fumes
  15. voorhees
    16,218
    2,033
    so okay your right I'm wrong but whats saftly ;)
  16. paddy
    5,276
    165
    Saftly is a special word we use down south when we cant spell the real one :yes:
  17. baz1
    baz1 New Member
    23
    turned out to be faulty front lambda sensors. The front two. The guy at the garage quoted my £400 including fitting!!
    Is it me or is this far too expensive?
  18. paddy
    5,276
    165
    Baz
    See my post above....... number 8 !!
  19. baz1
    baz1 New Member
    23
    Was that 200 quid for both of the front lambdas?
  20. edition
    1,426
    they look easy enough to get to......
    How much are they each?
  21. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    Sorry, couldn't resist!
    //R
  22. voorhees
    16,218
    2,033
  23. FactionOne
    3,272
    183
    That's not very mice. There's no need to be so catty.
    But yeah, I guess I've been a little Photoshop-happy this weekend. I'll give it a rest, for now... :)
    Rob.
  24. paddy
    5,276
    165
    Baz
    My invoice was for one but it was only £74+vat...the rest (£149) was "investigation" as they put it...
  25. baz1
    baz1 New Member
    23
    which audi was that paddy?
  26. paddy
    5,276
    165
    That was for my A3, 3.2 DSG 2004.
    I used Audi Guildford.
    I just checked the invoice and the part was actually £93 but i got 15% discount because the old girl is over 4 years old ie: £79.14p.
    hope that helps...
