Effin' pile of shi...........
scoobyra Oct 2, 2010
  1. scoobyra
    scoobyra It's not f@cking ORANGE!!!!!
    798
    After finally managing to start the car today, it was running fairly rough so I decided to run a diagnostic and found a few really odd issues as follows:
    Voltage reading high on cylinder 2 - twice as high as the other three.
    MAF reading all over the place.
    Ok, so, I swapped the coils packs round - still same voltage fault. Changed the MAF, still same erratic readings!!!
    I'm now completely stumped as VAG COM says there are NO FAULTS!!!
    Another interesting thing found - switching between stock map and revo makes bugger all difference so I'm beginning to think that the revo map is causing all the problems!
  2. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    Hope you get it sorted mate. Annoying when car doesn't run right.
  3. DAylward
    DAylward Member
    66
    so do you need a lift next weekend then? :) or do you rekon you can sort it,Sounds to me like the plugs are fecked.Have you ever changed them?
  4. Sandip
    2,454
    98
    Have a look at your plugs after you have tried to start it, sounds very similar to my issue and mine turned out to be a cracked head:(
  5. 1animal1
    9,978
    your stock map is another version of the Revo software so prob not a fair commentb(as in its Revo's version of stock rather than the proper one)....hope you get it sorted mate
    you prob have done this already....have you checked the wiring going to the coils?
  6. <tuffty/>
    21,235
    3,876
    Earths... as mentioned in your other thread mate, you are having quite a few electrical issues at once it seems... earthing problems can contribute to this... sounds like wiring probs from what you have been saying...
  7. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Take the airbox out and underneath that you will see a black panel which runs from the strut brace and curves under the airbox. If you take the panel strip off you will find a wiring loom in there which runs to the battery. I had problems with mine a while back, i don't know how the wires got bodged but my mechanic was clever enough to re-do the damaged ones and solder them up! Car was perfect after that.
    When this happened my car wouldn't start at all. I had it on vag-com which brought up many faults! Coilpacks 1 2 3 4 high voltage blah blah what you have, N75, MAF, Earth something something etc... Sounds like the same **** i had!
  8. Welly
    Welly VX220 SC Driver :)
    10,696
    128
    LOL, yeah, those wires can be a true and complete minefield. I know! lol.
  9. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    The coil pack wiring seems to suffer greatly from heat. they get baked upthere above the turbo.
    I would go checking all the earths too. and the secondary fuse box ontop of the battery too.
    I also had the problems of a plug getting tired... as in the metal inside the plug which is ment to be springy and touch the pins on all the electrical connections around the engine bay had gone loose. So there was a hit and miss signal . There for me was two options... use a very small screw driver to pull these pins back together so they connect tightly when plugged on.
  10. scoobyra
    798
    Thanks for all the useful advice. If it ever stops raining I'll get outside and have a look.
    One thing I did notice yesterday after changing the spark plugs is that the coil pack plug on number 2 cylinder (the one with the issue) has the little clip broken that keeps it on - maybe it had worked it's way loose and was causing some form of short?? I'll be plugging it back in to VAGCOM again tomorrow so I'll let you know how I get on.
  11. 666markyboy
    666markyboy Well-Known Member
    1,211
    49
    Speaking of earthing... has anyone tried this ??? Waks Wide Web i'm getting a slight hiccup from the engine every now and then when on part throttle and very slowly increasing speed ... if i go full bore it's not there and if i leave it on cruise control it dosn't do it so i'm thinking of doing this as a way of just bolstering up the ignition system... if it was a missfire am i right in thinking vagcom would show it up ?? as it's showing no faults..... also wondering if the MAF maybe due a clean as it's de-meshed and on a K&N filter...
  12. DAylward
    DAylward Member
    66
    so have you found the problem with it yet?
  13. scoobyra
    798
    Nope! It seems to be running a lot better with the new plugs but we can't work out why the maf is all over the place and cylinder two is twice the voltage of the other three!
  14. DAylward
    DAylward Member
    66
    you still going to make it on saturday? or do you want a lift
  15. scoobyra
    798
    It'll be fine, even with my lowering spring - yep spring!!! Only managed to get one on tonight courtesy of it getting dark too quickly and euro car parts supplying the wrong flipping top mounts!
    Note to self - drive very slowly!
  16. DAylward
    DAylward Member
    66
    jeez....you car sounds more and more like something from wacky races
  17. scoobyra
    798
    We're going to do the other spring and top mount tomorrow night. We weren't actually going to fit the H&Rs but Iain couldn't find his spring clamps and we couldn't refit the old spring as I couldn't get the nut on. Simple solution, fit the shorter H&R spring!! The knocking noise was a shot bearing!!!
