Effects of a clogged EGR
clockwork.satan Jan 11, 2012
  1. clockwork.satan
    clockwork.satan Vorsprung Durch Yer Maw
    62
    Hey guys,
    I've had my A4 140Tdi for about 3 months now and it's running great, however I'm beginning to think that it's drinking a bit too much fuel, seems incredibly smoky when I floor it and I've had to top up the oil level twice now.
    Are these symptoms all linked with a dirty EGR?
    The oil bit worries me the most as I owned a BMW-engined Diesel ZT for four years before this and never once had to top the oil up. And, if this is the case, is there a step-by-step guide anywhere on how to clean the EGR? Or, even better, is there a way to blank it off?
  2. Stepho
    Stepho Member
    444
    Smokey usually means burning oil, which is more likley to be the valve stem seals/turbo seals rather than the EGR. When mine went it lost total power, at first I thought the auto box had gone, really struggles to move. The EGR is also expensive around £250 + labour + VAT.
  3. clockwork.satan
    62
    Hmmm, might get that checked out sharpish then!
    Thanks for the heads-up, mate!
  4. Fahim
    Fahim Member
    278
    Blank the EGR valve. Ebay 'EGR blanking plate Audi A4' and tick the box including the description for search purposes. You should find them.
    You will need to remove the EGR function from the ECU by remapping the vehicle. R-Tech charge £40 iirc.
  5. clockwork.satan
    62
    Aaah, excellent! I did that with my last diesel and it made a big difference. I'll definitely get that done!
    Cheer for that!
  6. *Adam
    *Adam Member
    55
    I removed the cooler and EGR pipes, blanked both intake/exhaust sides up and all the vacuum lines without any mapping to the ECU or faults logged.
    What colour is the smoke? Black (unburnt fuel) or blue (oil)?
  7. Wrath
    Wrath Well-Known Member
    1,196
    42
    Just clean the EGR, takes about an hour.
  8. clockwork.satan
    62
    It's difficult to say, as I only ever see the smoke in the headlights of cars behind me. I'll try to get a good look at the colour of it tomorrow. Suffice to say that there's a fair bit of it, and judging by what Stepho said about the Stem/Turbo seals and the fact that my A4 seem to drink oil, I've got a feeling that it's probably slightly blue.
  9. clockwork.satan
    62
    Anyone got a guide on how to do this? I don't fancy tackling anything without having a rough idea on what to do...
  10. Wrath
    1,196
    42
  11. lamonby
    lamonby New Member
    Hi,
    I think I may be suffering from similar issues, and would be interested to know if these sound like EGR issues or something different.
    -On starting the car turns over fine and will idle for about 5 seconds before cutting out as if it had been starved of fuel or air. You can then re start the engine and it will run for a few seconds before then cutting out again. This is accompanied by black (Sooty) smoke which is why I thought either over fuel or lack of air.
    I had a diagnostic plugged in by the RAC guy who could find no boost pressure or injector codes, and only a bizzare code he had no idea about which I now think from reading a post on the site as an engine mount vibration sensor, which has probably tripped due to engine rumble before it cuts out (My guess).
    Before this had happend it also displayed the following (Possibly un realated)
    - Engine would run and idle fine, however if dipped the clutch while driving and let the revs drop off they would keep dropping past the idle point and the engine would cut out. You could then restart and it would run fine.
    - Once when driving there would very little power and the car would slow, then if you put your foot down there would be a delay before hearing the turbo run up (loud) and a burst of power.
    Any body have any ideas or suggestions?
    Ross
  12. Wrath
    1,196
    42
    A clogged EGR valve causes some weird symptoms but usually there is smoke. Whether or not the car has symptoms I would always recommend cleaning the EGR. My car gets a regular bit of acceleration so wasn't too bad but my stepdad's Seat had a huge buildup of carbon and the effects after cleaning we even obvious to my Mum. Get some Wynns carb cleaner from Halfords and do it today.
    lamonby likes this.
  13. lamonby
    lamonby New Member
    I disconected the pipe between the turbo and the EGR valve and managed to get the car going (Although very smokey). Very little torque when driving back home, but am convinced that it is to do with the EGR & not an injection problem. I have used that stuff not too long ago, but if its as baddly full of carbon as some of the other posts I have seem its going to need to be dowsed in petrol for a night to remove. Not got much time today but I shall post the pictures of what I find before I clean. Not driving until I know I have sorted the problem!
  14. Wrath
    1,196
    42
    Nah, don't leave it soaking. Take it out, apply a bit of Wynns and use a fat screwdriver to scrape the carbon out. Every so often use a bit more Wynns. Did this with a Seat Leon that was quite bad, took about 15 minutes to scrape it all out.
