EDL a4 1.8t quattro 2000
audii Dec 29, 2006
  1. audii
    audii Member
    hi evrey one i have a audi a4 quattro sport 1.8t but im not sure if the edl is working how can you tell if its working / how do i know if its fitted etc because i parked on a grassy verge the other day adn two wheels where on the grass so other traffic could pass easly but when i came to drive away the wheels on the grass kept spinning i did move off in the end but EDL is suposed to stop this sort of thing
    i heard no sound from the brakes and no pulling from the stearing to sugest that the EDL had applied the brakes if some one could help descibe how it works and what it feels like when triggerd at least ill know if its fitted /working thanks:undwech:
  2. docurley
    4,073
    88
    You should have a button on the centre consul with an ESP button if not then you don’t.
  3. audii
    audii Member
    i thought EDL was part of the ABS not the stability program ASR or ESP any body els have any idea about this sort of thing thanks chaps
  4. a4quat
    a4quat Member
    374
    i dont have no esp button
  5. SteveS
    SteveS S6 avant
    691
    my 2wd a4 had an esp button but the quattro i have now does'nt. older quattros had a torsen centre diff and a manual diff lock for the rear axle but what do a4's have? i thought newer ones had EDL or have audi just done away with the diff lock thing? its difficult to test it unless we get some snow to play in:sm4:
  6. 205man
    205man Active Member
    1,072
    14
    yours doesnt have an esp button steve?
    our car cars are the same age/year arent they but mine has one fitted??
    alan
  7. SteveS
    SteveS S6 avant
    691
    no, mine has a blank in the dash where the switch should be (next to foglamp switches) but ive never had any trouble with wheelspin or getting stuck, in fact its amazing how fast you can pull away on gravel or grass! mine is auto though if theres any difference.
  8. 205man
    1,072
    14
    mines also auto/triptronic maybe it was down to when in 99 it was released, mine a very late 99 was bought on xmas eve
    alan
  9. GSB1
    GSB1 Member
    283
    All B5 quattros have EDL I believe regardless of ASR or ESP.
  10. audii
    audii Member
    any one have any more answers
  11. m0rgb
    m0rgb New Member
    My 03 A4 quattro has an ESP button if that's any help?
    Gary
  12. John@ECM-TECH
    John@ECM-TECH Owner Site Sponsor
    305
    79
    Try getting the Haldex checked/serviced? Is this not what does the tricks?
  13. enda1
    enda1 Member
    436
    A4 don't have a haldex they have torsion diff. The haldex is only in cars with the golf derived chassis where the engine is transverse i.e. TT and A3
    Electronic differential lock
    "The electronic differential lock (EDL) is an aid when driving away from a standstill. An electronically controlled brake application on the spinning driven wheel provides a torque reaction point for the differential. This enables the wheel with better traction to make use of the engine power. This also applies when reversing.
    EDL is standard equipment on vehicles with 4WD. While EDL acts on all four wheels in vehicle with 4WD on vehicles with FWD it acts only on the front wheels. A mechanical differential lock is not required.
    The EDL control function can be initiated at road speeds up to 40 km/h. Once EDL has been activated it cuts out automatically at a predetermined upper speed threshold of 40 km/h on vehicles with FWD and 80 km/h on vehicles with four wheel drive.
    Suction dampers are fitted in the hydraulic unit. They assist the build-up of pressure in the corresponding wheel brake cylinders when EDL is active. The operating range of the pressure limiting valve in the hydraulic unit is 170 ± 25 bar.
    To stop the brakes overheating the EDL control function is suppressed if the temperature of the brakes exceeds a certain value. The temperature value is defined in control unit-J104. The temperature of the brakes is calculated by the control unit using a simulation formula. The EDL is then reactivated if the calculated temperature drops below a predetermined lower threshold. The operation of the brake system and the ABS function are not affected by this automatic cut-off feature.
    When the ignition is switched off, the calculated temperature of the hot brakes is stored in the memory until the ignition is switched on again. When the ignition is switched on, the dash panel insert sends a time signal which enables the control unit -J104 to calculate the period the vehicle has been left standing. This period is put into the temperature simulation formula to calculate the new temperature of the brakes. If the vehicle has been left standing for more than one hour, the control unit will automatically assume a brake temperature equal to the lowest value in the simulation formula.
    If EDL is switched off due to temperature limit being exceeded this is indicated in measured value block for a period of 20 ignition cycles.
    Dash panel insert with FIS
    ◆ The warning lamp -K118 is not supplied with DIS. The red brake fault symbol appears in the display.
    ◆ If the brake system is not fully functional, but the ABS/EDL warning lamp -K47 and the red brake fault symbol do not light up, this means the fault must be sought in the conventional braking system (mechanical/hydraulic components)"
    If you need any further help i'll get what I can from elsawin
