ecu wont except remap ?
bristol s4 Apr 20, 2008
  1. bristol s4
    bristol s4 New Member
    9
    anyone else had problems remapping s4, just took it 2 forge motorsport and laptop could get no response from ecu so was unable to remap it, anybody know why this might be as they have never come across it before ? cheers, justin
  2. bahnstorm.net
    bahnstorm.net Member
    50
    what model yr is it?
  3. John@ECM-TECH
    John@ECM-TECH Owner Site Sponsor
    305
    79
    bet you it's a NDW model with the read only ecu, on those you neeed to completly replace theh ecu with a freshly burned one
  4. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,778
    33
    I've got an October 98 S4, so one of the first ones made. MRC mapped mine without having to replace the ECU.
  5. Broken Byzan
    13,244
    468
    On the earlier ones its a replacement chip job on the ECU, the DBW models with the later ME7 ecu can be flashed
  6. bristol s4
    9
    cheers guys 4 the response and info, is it worth me trying somewhere else or do i need new ecu ? s4 is a 98 if that makes any difference ?
  7. bristol s4
    9
    thanks byzan a4 for that, so if thats the case whos the people 2 speak 2 about new chip ? and how much should i be looking at paying for this pleasure ? regards ,justin
  8. Broken Byzan
    13,244
    468
    Chip n spin on this forum could do the chip swap for around £250 ish
  9. Blue_Thunder
    1,778
    33
    You do not need to replace the chip in an S4!!!
    All S4's are DBW, and all can be mapped via the OBDII port.
  10. bristol s4
    9
    thanks mate , where will i find them on forum as im desperate 4 a couple of new horses 2 play with ?
  11. bristol s4
    9
    dont mean 2 sound thick although bristolian accent would suggest otherwise:tocktock: but what is obdII ? im quite new 2 this modding malarky !
  12. Chip-n-spin
    Chip-n-spin ECU Remap & Tuning Specialists
    411
    98 S4 will need the chip replaced or at least done on the bench in boot mode. Not possible to do over OBD. This is true for most VAg ECU's upto September 1999. There are of course some exceptions to the rule.
    Thanks.
  13. bristol s4
    9
    definitely interested in getting chip done, where about u based 2 ?
  14. Blue_Thunder
    1,778
    33
    My ECU was removed from the car the first time to 'unlock' it, but i've since had 3 remaps done via the OBD.
  15. Broken Byzan
    13,244
    468
    I wish mine could be done like that, i am on my 3rd chip already, really need a socket i think
