ECU UPGRADE !!
Bradderz_1988 Feb 19, 2013
  1. Bradderz_1988
    3,899
    230
    Whats involved in swapping the ECU in my TQS to a AGU ECU, could someone specify the full ins and outs ??
    might look at doing this if it seems a good route to go !!
  2. aragorn
    17,887
    688
    more or less a streight swap.
  3. Bradderz_1988
    3,899
    230
    When you say more or less whats involved ?? What pin layouts need to be changed or parts need to be added IE oil level sensor etc ???
  4. aragorn
    17,887
    688
    Nothing, just plug it in, code the immo and drive. Then remap it as you see fit.
    Mark had some issues coding the immo on his one iirc and ended up disabling it.
    Also it needs to be a specific AGU ecu, the earlier ones are rubbish. I THINK its an 018CJ you need.
  5. Bradderz_1988
    3,899
    230
    Can you recode the immo through vagcom ??
  6. aragorn
    17,887
    688
    yes, but you need the SKC for the cluster and ECU, which will require vagtacho or similar.
  7. Bradderz_1988
    3,899
    230
    The AGU is 150bhp so would need to swap it over wnd code it when it would be getting mapped ??
  8. Broken Byzan
    13,235
    464
    me7.5 is where its at, AGU ECU is so 2 yrs ago.
  9. Bradderz_1988
    3,899
    230
    TBH i havent got the time or money to do the me7.5 conversion dont get me wrong i would love to have that setup, i was just thinking of labour costs involved to map these cars ie chip out, socket soldering and using chips to get the proper map setup in the car.
    when im ready to get the map (when i pull my finger out lol) il be going to unicorn in stockport.
  10. PaulJC84
    PaulJC84 Owner
    2,888
    13
    I will be interested in how you get on. I would like to get a custom map and think swapping to an agu will give me more options.
  11. aragorn
    17,887
    688
    Didnt you sell your K04? No point wasting money custom mapping a stock turbo IMO.
  12. Broken Byzan
    13,235
    464
    TBH, if you are going to use Rick and get him to solder a socket on etc, you just as well use your ECU and have it all done to that. I wanted flashable becasue i knew my spec would change. so flashable seemed the way forward. Otherwise, there is nothing wrong with a dumb ECU, niki has extracted 344 from Prawns hybrid race car with no problem using an emulator,. Emulate lots, solder once
  13. PaulJC84
    PaulJC84 Owner
    2,888
    13
    Yeah I am meaning for in the future, hopefully get something bigger than the K04.
    Already paid Star £500 for my map on the standard turbo and decat about 8 years ago so not going to map that again.
  14. Bradderz_1988
    3,899
    230
    i was thinking an AGU ecu as i may want to go a differant route with the car ie stroker or BT depending on what bits i can get on a budget as of recently the scrappers i use actually no a lad i worked with who worked for them stripping there cars and they have my number if they have any citroen/peugeot related querys and jobs that they might have for me so i may be able to source a spare block and head from there for next to nothing as hes a sound guy and may sort us out and also other bits he has maybe an ABF crank lying around :) and slowly build it up bit buy bit. Well thats my plan but need to move house first and get settled and finacially stable as money burns a hole in my pocket lol
  15. Bradderz_1988
    3,899
    230
    Few q's on this subject,
    1. How easy is it to de immo the agu ecu
    2. Could i run the agu (stock map) with a 3bar fpr, 3" maf, injectors and fmic on stock rods etc ???
    3. i have analogue clock so will this be a relatively easy swap regarding immo2/3 and just be straight plug and play ???
  16. Broken Byzan
    13,235
    464
    Analogue clock is immo 2 and may adapt correctly, mine didnt for some reason i never fathomed, it'd adapt and light would go out, but car wouldn't run for longer than 3 secs
  17. Bradderz_1988
    3,899
    230
    Deviation codes i dont follow ?? If i buy vagtacho will it be easier to code the immo ??
  18. Broken Byzan
    13,235
    464
    Vag tacho will help yes, The ecu may flag up codes for boost deviation. Because your turbo flows more than it's expecting to see for a given load. That of a MAF signal too high
  19. Bradderz_1988
    3,899
    230
    Could that be sorted when it gets a custom map and some shiney new rods :) ??
  20. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,912
    164
    If its of any use, I have a couple of ME7.1 ECU's knocking around as im going WB. They are from an APU, and one has Immo defeated already.
