Ecu removal
20vtmk3 Apr 6, 2010
  1. 20vtmk3
    20vtmk3 Member
    76
    Hi guys, anyone know how to get the ecu off a 2001 s3. Ive taken the wipers and scuttle off, disconected the connectors and taken off the 2 10mm nuts that hold the cage but the rear of the cage is still stuck!! Any ideas????
  2. Lemon S3
    Lemon S3 Alex
    1,390
    41
    I didnt have to undo any nuts round the ecu, just pulled it out, is a bit of a tight fit though.
  3. 20vtmk3
    20vtmk3 Member
    76
    Thanks mate, i didnt want to pull it to hard incase something broke. Thanks, ill give it another go
  4. sekenzo
    sekenzo Member
    102
    Suppose it is similar to an A3, there should be a metal catch to the right of the ECU (view from front) that just catches the corner of the ECU housing which you need to just gently push away with a screw driver. The ECU should slide out easily...
