  1. imported_berty
    imported_berty Guest
    When I scan for fault codes with VAG-COM the fallowing codes appears:
    17563 – Short to B+
    P 1155-35-10……………intermittent
    17565 manifold pressure sensor G71: supply voltage
    P115735-10……………..intermittent
    First of all I change the G71 G72 4 wire sensor. I check the wires from the sensor to the ECU with Ohm-meter and they are ok, but the errors are still there and cannot be deleted.
    In diagnostic mode the N75 Solenoid valve (vacuum) moves, but when I command to move up it move down and when the command is down it moves up, so that is OK J
    In a disparate move I change the ECU with an older version without immobilizer, and I have no errors and for 3 or 5 seconds the engine runs well (the N75 Solenoid valve begins to move the arm for vacuum …..) /ubbthreads/images/graemlins/smirk.gif
    This message “manifold pressure sensor G71: supply voltage” it means the ECU not power supply the sensor? If this is true, can I do something? The ECU can be repaired? Or I have to buy one /ubbthreads/images/graemlins/shocked.gif
    Volkswagen Passat Wagon 2002 1.9 tdi ECU EDC15P+
  2. audi5e
    audi5e Member
    809
    have you tried using electrical contact cleaner on the plug that connects to the ecu?
    maybe also try using this cleaner on the contacts on the ecu.
