Econ light won't switch off - No Air con!
richiwildchild Sep 23, 2012
  1. richiwildchild
    richiwildchild New Member
    17
    I have a 2005 A4 which appears to have an air con problem. I have no idea how long it has been like this as I usually leave the ECON button on, but I tried to switch it off the other day and it just wouldn't. Has this happened to anyone else out there, and any ideas what the problem might be? :blackrs4:
  2. willowsdad
    willowsdad Sideways
    1,027
    32
    Could have lost its gas. I think they're designed to be left on most of the time, to keep the system lubricated. If its not used often enough it can cause problems.
  3. RMH1A4cab
    RMH1A4cab I'm in Cruise control
    551
    19
    Could be a number of things, re gas, pressure switch, compressor. Needs to be scanned with vcds to pin point exactly.
  4. I have this same problem on my '07 S3 8P.
    I did a scan and got the follow error regarding the fan for the interior temp sensor.
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AD HW: 8P0 820 043 AD
    Component: KlimavollautomatH19 0360
    Revision: 057901 Serial number: 8P0820043AD
    Shop #: WSC 00000 000 00000
    VCID: 6ED87AA079B38B68C39
    1 Fault Found:
    00796 - Fan for Interior Temp Sensor (V42)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 57
    Mileage: 44463 km
    Time Indication: 0
    Date: 2012.09.22
    Time: 16:48:55
    Freeze Frame:
    Voltage: 13.80 V
    Temperature: 32.0°C
    Cleared it and it hasn't come back. The ECON light still won't go out. There are no other errors shown by VCDS. Is this likely to just be in need of a re-gas? I had a new air-con compressor last summer (2011) as the original had failed. I would've thought it shouldn't need a re-gas until next summer.
  5. hades-
    9,481
    646
    low gas or preasure switch
  6. Wouldn't the pressure switch show up on VCDS as an error though if it was the suspect?
  7. hades-
    9,481
    646
    not always go to halfrauds for a free check on the gas
