econ button
williams Feb 9, 2011
  1. williams
    williams Member
    78
    if econ light is on is air con on or off:unsure:
  2. hades-
    9,481
    646
    aircon off
  3. aragorn
    18,542
    865
    If the light is on, ECON is on.
    ECON disables the AC.
  4. jey
    jey Member
    229
    its stupid isnt it lol when all the other buttons are lit they indicate on!
  5. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Lit = ECON on, so it's lit when you selected ECON - seems totally sensible to me?
    If you want it lit when the A/C is on then the button should be labelled A/C and not ECON.
  6. jey
    jey Member
    229
    the manual states if econ light is lit then econ is off! bit confused. when ive the econ light off the air is freezing cold.
    whats the difference between econ and A/C dave??
  7. Wrath
    Wrath Well-Known Member
    1,196
    42
    Air con conditions the air and with climate control can control the temperature no matter the heat outside.
    You will notice the difference in summer when it is 25 degrees plus. With the econ lit you will have warm air blowing your face, with Econ off you will get the air con on meaning cold air will fill the cabin.
    Econ lit means the air con compressor is switched off so you get a small fuel saving.
  8. jey
    jey Member
    229
    rite get ya. cheers..
  9. yavz
    yavz New Member
    Editted post as Wrath answered my question.
    Econ on helps save fuel a little.
  10. Dazmo
    Dazmo Active Member
    1,762
    I never really saw the point in econ really.
    Its useless when its on anyway as it only lets the air in from outside and disables everything else so whats the point really?
    It does not warm anything up if you want it warm and does not cool the air if you want it cold.
    You might as well just wind your window down.
  11. aragorn
    18,542
    865
    eh?
    The only thing ECON does is disables the AC compressor (it may also disable recirc, but ive never tried that because its next to useless anyway).
    The heating still works perfectly normally, as does the cooling, except it can only cool the car using fresh air from outside, rather than chilled air thats gone thru the AC system. Ie in the middle of summer, then yes, ECON is a bit ****, but no different to any other car without AC. Any other time ours stays on ECON, as i dont see the point wasting petrol to power the compressor and big electric fan, when its 10c outside.
  12. Wrath
    1,196
    42
    You can have recirc and Econ on at the same time.
  13. aragorn
    18,542
    865
    Cool, so Dazmo is just making stuff up then!
  14. Wrath
    1,196
    42
    Yeah, Dazmo's a liar :laugh:
    Or his car's broken :crying:
