ECON & AUTO on together??
pazaz Mar 17, 2011
  1. pazaz
    pazaz Member
    323
    When I put my climate control on the ECON light stays on too??
    If I hold the ECON button in the ECON light goes out. As soon as I release the button them ECON light comes back on.
    Is this right?
    cheers..
  2. Smoothie
    Smoothie Active Member
    1,431
    Press auto, or a directional button
  3. pazaz
    pazaz Member
    323
    When I press AUTO Nothing happens.
    When I press a directional button the AUTO light goes off and ECON light stays on.
  4. aragorn
    18,315
    809
    ECON light being illuminated means the AC is off.
    The fact it wont turn off indicates your AC is broken.
  5. FranA3
    FranA3 FMDETAILING Regional Rep Site Sponsor Gold Supporter Audi A3 Team Brill Red
    7,235
    328
    yeah it should turn off when you put it in auto and if you push the econ button get it looked at
  6. NHN
    29,333
    1,717
    Check your fuses as this can happen if one blows.
  7. Smoothie
    1,431
    On the facelift climate, ECON has become A/C
    So does this still mean that AUTO illuminated is A/C on?
  8. NHN
    29,333
    1,717
    Auto will illuminate when none of the directional air buttons are on iirc.
  9. pazaz
    pazaz Member
    323
    Bugger!! Checked my fuses and they are all ok.
    Would this show up a a fault code if I took it to a garage to diagnose the part that needs replacing?
  10. pazaz
    pazaz Member
    323
    spoke to a automotive air con specialist today who confirmed it might need re-gassing (£30) to sort this fault out.
    Any body know if this is sounds about right?
  11. pazaz
    pazaz Member
    323
  12. NHN
    29,333
    1,717
    £30 isnt bad at all for a regas.
    Have you had car scanned as yet?
  13. markie A3
    markie A3 Member
    149
    Would vcds cover heating and cooling faults? Mine has no fault codes, yet won't cool the car, so does this mean it needs re gas or a leak sorting if any?
  14. pazaz
    pazaz Member
    323
    If it does I will get it scanned first
    Is re gasin an easy process then?
  15. NHN
    29,333
    1,717
    Regas is easy with the right tools yes, depends on the fault tbh, but it can show some sensor/climate issue & as for does it need regassing, need to take to somewhere with kit & they can check if it needs doing.
  16. jfow
    jfow Member
    39
    Yeh it just needs the Gas re-filling its unlikely it will be anything else.
    £30 is a great price, takes about an hour...
