ECON allways on
SinghB7 Jul 14, 2014
  1. SinghB7
    SinghB7 Active Member
    534
    69
    Slight problem with my air conditioning, the light on the ECON button is allways on even if you press it it stays on.
    is this because theres no gas in the system? Just thought i'd ask before I go pay to get it re-gassed
  2. drew306
    drew306 Member
    41
    I think your right mate. Do a search on here, I'm sure I read it in a post a couple of weeks ago, I'm sure it was in a post about getting the oil pick up pipe changed.
    Hope this helps.
  3. ruffrida
    ruffrida Well-Known Member
    1,937
    315
    Common problem on the B6 mate, your Aircon needs regassing first, then it could be condessor, etc etc etc, check the B6 section out, we have had many discussin over this lol
  4. Geebo
    Geebo Member
    50
    24
    This happened to me in & my case it was just a re gas to fix it but there are other things which can cause the Econ to stay on as stated in the other posts.
    I'd try a re gas first.
  5. V6 Quatt
    V6 Quatt Well-Known Member
    1,248
    441
    Needs a regass
  6. sewell10
    sewell10 Member
    236
    High pressure sensor fault
  7. Paul B7
    Paul B7 Active Member
    622
    34
    I have had this symptom on two occasions.
    Once when the compressor seized and I needed a new one,
    Second time when the pressure switch ( behind the near side headlamp) failed
    and it can also occur if the system needs a regas or has a leak .
    Good luck, I hope its the cheap regas option?
