EBC TURBO GROOVE
ramp1990 May 11, 2013
  1. ramp1990
    ramp1990 Member
    81
    13
    Hi well ive been searching past view days on reviews for the disk, found plenty of old ones but nothing recent, so im loooking for personal experience not a friend of a friends brother said they were rubbish lol. There bit more then OEM but there zinc coated look big special and if there abit better and dont melt im happy :) thanks
  2. SPARTAN91
    SPARTAN91 RED FIVE STANDING BY Regional Rep Team Silver Audi A3 TDi
    484
    166
    43
    Are you asking about these ones
  3. max69vk
    max69vk Active Member
    862
    57
    Save your money & buy some decent pads. Grooves, dimples, drilled holes are all pretty much a gimmick on a road car.
  4. coreythorny
    coreythorny Active Member
    463
    74
    I wouldn't say they were a gimmick. People just need to use a setup appropriate to their needs. People run grooves etc on normal road driving and expect to have magically transformed their brakes into 8 pots. Grooves are designed to dissipate heat better and clean the pad face, drilled and dimpled just help heat dissipation.
    People also tend to get a upgraded pad which 9/10 times are designed to work at higher temperature than OE pads. So you can buy uprated pads and discs then find under light driving they're no better to use.
    You need to find a setup applicable to your car. I had EBC turbo grooves and Tarox Strada pads on my last car. Against OE they were arguably a bit worse cold. However one sharp brake and some temperature in them they were another setup. The grooves helped on track days to stop the pads glazing by dissipating heat and cleaning the pads.
  5. S3Alex
    10,804
    4,805
    Likewise,I wouldn't say they're a gimmick,and have used cross drilled or grooved discs on a number of road cars,but only as part of a fully upgraded brake system,and I think that uprating only one area of a system will result in limited gains.
    I'm from the school that says wait and save to uprate the entire brake system and get much better results.
  6. ramp1990
    ramp1990 Member
    81
    13
    EBC Turbo Grooved Front Brake Discs AUDI S3
    these ones??
    i dont mind the stopping power of the standard brakes there warped so looking to replace them, my brakes get quiet hot down country roads and would want something that doesnt fade. There not much more then standard disks so if these can take the heat. Will be doing a fluid change at the same time, and full service. I dont fancy spending 2k on a big brake setup not because i dont think its worth it, just because i dont want to spend 2k on a already big list of mods lol
  7. max69vk
    862
    57
    In reality Alex you probably put the point across better than I have after a few bevvies, however the point remains that on a road car with no other brake mods there'll be very limited if any differences in braking capabilities (hence me saying its a gimmick). For the money being spent on a set of 'performance' discs the money would be better spent on some decent pads & stainless steel brake lines.
  8. S3Alex
    10,804
    4,805
    Fair enough.
    If the current set is warped,then there's little to lose by trying an aftermarket set of discs.
  9. SPARTAN91
    484
    166
    43
    The disc in the picture are EBC new compound high carbon steel (which I have ordered) and are the next grade up from the turbo ones.I got the ulitmax ones at the moment with the green stuff pads which I had on for nearly 2 years and and along with the stainless steel brake lines I'm ready to fit have made a difference just need to warm them up first to get the best out of them plus I,ve just remaped my car so I,ll stick with the EBC.
    ramp1990 likes this.
  10. ramp1990
    ramp1990 Member
    81
    13
    Thats all i needed to see. I'll be ordering my disks this week after pay day. And i'll be reviewing them after a few weeks living with the disks setup.
  11. Reload
    Reload Bird is the Word!
    367
    49
    I have the EBC Ultimax discs and yellowstuff pads. Not a massive amount of love for EBC around here, most people seem to have a friend of a friend who knows someone down the pub who's brother's father's sister's boy has a set of EBC brakes explode on them :wtf:
    To be honest I'm quite happy with them and wrote a user review a while back to that effect
    SPARTAN91 likes this.
  12. S3Alex
    10,804
    4,805
    Aliens ate my brake calipers....
    Seriously,my only beef around EBC is their pads,which were underwhelming at best,but like everything else,brakes and how they feel are a very personal thing,and many people are happy with these.
  13. ramp1990
    ramp1990 Member
    81
    13
    did u get round to fitting the carbon disks?
  14. ramp1990
    ramp1990 Member
    81
    13
    Disks and pads should be here today/tomorrow any thing else worth changing while im doing the disks? fluid change / brake lines? cheers
  15. SPARTAN91
    484
    166
    43
    Virdee likes this.
  16. ramp1990
    ramp1990 Member
    81
    13
    Well they came just need few more parts and fluid thennn fitting :)
