ebay vagcom voltage help
mad cornish pastie Oct 16, 2010
  1. mad cornish pastie
    mad cornish pastie Audi novice handle with care
    81
    sorry i did read, but can't find the info on here that if you buy the cheap ebay vagcom it will not work or burn out the cable if an after market radio is fitted as it pushes up the k line to 12volts. anyway can someone point me to the thread were the port can be volt tested and if neccesary put in a resister if i read/remember properly.
    many thanks newbie phil
  2. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
    Are you referring to the Ross-Tech Aftermarket Radio Problem page? Brought to you by the people who sell the real deal. Your eBay supplier will give little to no help.
  3. mad cornish pastie
    81
    cheers for that, i only want it to turn off the airbag light...
  4. NHN
    29,596
    1,782
    Then I suggest you do 1 of 3 things, buy the genuine article, ask a member with the genuine article to do or get audi to do this for you, ebay leads are ****
