Ebay vagcom lead drivers
diesel-a4 Oct 15, 2008
  1. diesel-a4
    diesel-a4 Stoned As Fuk
    162
    am after a copy of the driver cd you get with the ebay leads as ave lost mine only looking a quick scan for errors and its taking 3 days :(
  2. NHN
    29,279
    1,692
    This is prime example of why to buy genuine fella, so 3 days later wasted & a lead not much good as is, you have to admit its a good reason to get authentic
    Problem is ebay leads are different versions so drivers will also be different I have found when I've checked ini files etc ages ago when I made the big mistake of buying cheap one, so you could ruin the lead by simply installing wrong drivers.
    Get yourself an original & never have this problem again.
  3. diesel-a4
    162
    theres no way am spending £200+ on something thats only gonna get used once in 6months mate, that money would be well spent some where else. i just want to scan for error codes so £200+ just for that is steep
    were not all loaded :)
  4. NHN
    29,279
    1,692
    Who said I was loaded, now its 4 days huh lol
  5. diesel-a4
    162
    u would need to be. my local mechanic has some APR hand held device that does almost all i have needed apart from a scan.
    i found the driver gonna give it a spin tonight and if it don't work i may hold out till end of the month til payday :(
  6. aragorn
    17,806
    679
    The "driver" for the ebay cables is just a standard windows USB-Serial driver
    The ebay leads use an older lead design with a serial based interface, then use a USB to serial converter to allow it to connect to the USB port on your laptop
    I also agree with you about the price. I can afford to take a chance on £10, i cant afford £300 to read some fault codes off though.
    i use the old 301? software with mine and it works perfectly fine. You may need to adjust the settings on the USB-Serial driver to get it onto one of the first 4 COM ports, mine came up as com7 initially but you can move it in the control panel.
  7. diesel-a4
    162
    well the scan is done:
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Address 01 -------------------------------------------------------
    Controller: 038 906 018 S
    Component: 1,9l R4 EDC 00SG 1621
    Coding: 00002
    Shop #: WSC 06335
    1 Fault Found:
    00575 - Intake Manifold Pressure
    17-10 - Control Difference - Intermittent
    Readiness: N/A
    Address 03 -------------------------------------------------------
    Controller: 8E0 614 111 AB
    Component: ABS 5.3 FRONT D00
    Coding: 0273004281
    Shop #: BB 24548
    1 Fault Found:
    00290 - ABS Wheel Speed Sensor: Rear Left (G46)
    35-10 - - - Intermittent
    Address 08 -------------------------------------------------------
    Controller: 8L0 820 043 D
    Component: A4 KLIMAVOLL
    Note: Excessive Comm Errors
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 8D0 919 930 H
    Component: B5-KOMBIINSTR. VDO D03
    Coding: 04440
    Shop #: WSC 00000
    IMMO-IDENTNR: AUZ7Z0W0408972
    No fault code found.
    Address 25 -------------------------------------------------------
    Controller: Bitte Adress
    Component: e 17 eingeben
    No Faults Found
    or DTCs not supported by controller
    or a communication error ocurred
    Address 35 -------------------------------------------------------
    Controller: 8L0 862 257 G
    Component: ZV-Pumpe, DWA, Funk D05
    Coding: 13130
    Shop #: WSC 06335
    15 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch: Driver's Side
    35-00 - -
    01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01373 - Alarm triggered by Radio Ground Contact
    35-00 - -
    01361 - Switch for Anti-Theft Alarm: Close
    29-00 - Short to Ground
    01360 - Switch for Anti-Theft Alarm: Open
    01362 - Close Switch for Tailgate/Trunk (F124)
    01365 - Lock/Unlock Switch: Interior
    01571 - Signal for Seat Memory
    00991 - Interior Lights
    28-00 - Short to B+
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    Address 45 -------------------------------------------------------
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00101
    Shop #: WSC 06335
    3 Faults Found:
    01377 - Ultra Sonic Sensor for Alarm System: Left (G170)
    27-10 - Implausible Signal - Intermittent
    01378 - Ultra Sonic Sensor for Alarm System: Right (G171)
    01383 - Alarm triggered by Anti-Theft Sensor: Front Right
    35-00 - -
    End -------------------------------------------------------
    so wtf does all that mean
  8. meatychi
    meatychi Member
    261
    It looks like you have a lots of faults, possibly historic - I would reset the fault codes and re-run, in a week or so, to double check that these aren't redundant faults left from a previous owner!
  9. meatychi
    meatychi Member
    261
    I have to agree with Diesel-A4 on this one - I have a cheap ass ebay cable and it worked fine, it read and cleared my ABS fault codes after fitting my ABS ECU.
