Ebay Vagcom doesn't work with 8P A3/S3's
Lemon S3 Oct 14, 2010
  1. Lemon S3
    Lemon S3 Alex
    1,390
    41
  2. s8craig
    1,750
    55
    Probably because the A3 8P is CAN based diags and the lead you have is K line for older cars like the A3 8L chassis.
    It actually states most cars upto 2004 and the 8P came out in 2004
    You need a diag lead that supports CAN & K-line to cover all models, like a genuine ross-tech lead. I think they also have a micro CAN lead specifically for CAN only based cars I think.
  3. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Ah I see, thanks Craig. Think I might just splash out on the propper kit from ross-tech.
  4. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
    The MicroCAN will work with the 8P A3 but it will not work with most other CAN based Audis. If you want to work on other Audis, you should consider the HEX+CAN style interfaces. Our distributors in the UK handle these interfaces including NHN here on this forum.
  5. vw754
    vw754 vorsprung Durch Technik
    2,329
    58
