Easy Haldex Fuse question
cptn_molo
Ok i have searched the forum and my user manual but cannot find the answer........
I suspect my Haldex has a problem - and the first check to do is the fuse. Some sites say fuse 31 - some say 33 but this does not tally with my user manual, where i cant find a mention of haldex in the listing for either fuse box????
I believe it should be a 5A
I have a 2007 2.0tdi 170 quattro and have the gen 2 controller.
any help is appreciated
Further to the above question - never found the fuse - tho i think its ok
scanned with vagcom and got the following:
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
Shop #: WSC 00000 000 00000
1 Fault Found:
01073 - Clutch Pressure System
002 - Lower Limit Exceeded - Intermittent
This code is not listed on the Wiki Ross tech list of faults so i am going to assume the following
1. Possibly has no/low oil - it is due a change
2. the pressure sensor is faulty
3. the pre charge pump is faulty :(
Have any of you guys had this fault ? solutions
much apreciated
Just to close the loop on this tread for anyone else with this problem.......
Just needed some oil in the coupling to get working
But every "how to" on the internet shows the coupling needing oil from a mastic gun type thing and you are only suposed to fill 275ml, but the 8p car with gen 2 controller needs 700ml (aprox) of oil which is thin (comes in a 1L container labeled Haldex coupling oil) and i had to fill from the inspection plug.
Put 700ml in but only got 100ml out so either i have a leak or the full audi service history with haldex oil changes every 20,000 miles is nonsence
Diff oil ok so its not leaking there.... no other signs of external leaks
All working now - happy days
10
SiT
705
10
