early style aeb ecu swap
sam80quattro Sep 4, 2009
  1. sam80quattro
    sam80quattro Member
    146
    hi, im putting a 1.8t into an audi 90 quattro, the 1.8t came from a n reg a4 and the ecu has 5 plugs on it and ive been told you cant remove the immobiliser from these 1s so i was wondering if i can simply change the harness and ecu from an early b5 to a later b5,a6, passat etc so i can have the more modern 2 plug ecu(which i know can have the immo removed). as long as i keep it drive by cable, is there other sensors to worry about etc? any1 done this? cheers :salute:
  2. Broken Byzan
    13,237
    465
    Cant you just get a 98.5 DBC loom and ECU and then get the immo removed using a flashable ECU from a 1999 A3 or Golf?
  3. sam80quattro
    sam80quattro Member
    146
    im not sure lol i know my a6 had the later style ecu and was also dbc. i can get the loom and ecu cheap but just wanted to make sure it would work. think i'll just try it anyway as there cant be that much different with the motors sensors if anything at all
  4. Broken Byzan
    13,237
    465
    You do know the early type ones cannot be chipped successfully any more due to lack of chips available.
    I would hold out for the later 2 plug type ECU and loom. The sensors are much the same, it's only the later modles that change drasticly
  5. sam80quattro
    sam80quattro Member
    146
    yeah its the later 2 plug 1 im getting, as the original to the engine is the 5 plug type. the newer style 1s can be chipped ok though cant they? as in a 98 a6 1.8t ecu? they have the 2 plug ecu.... thanks for the help so far
  6. Broken Byzan
    13,237
    465
    Yup, alter one is cool. ECU numbers 8do 997 558E or 557T are common for the 98 ish 2 plug style.
    We on here have been looking at using alternative flashable ECU's to allow for more functions , tunability , immo on/off blah blah !
    The loom in my car is from a 99 Passat, and the ECU is from an A6.
  7. sam80quattro
    sam80quattro Member
    146
    hopefully it'll be up and running soon then. just need to figure out were all the wires go lol
  8. Broken Byzan
    13,237
    465
    engine side they all only go to one place, the other end you need to run up that ELSAWIN to trace them as they link to the dash,the immo, etc
