"Dyno Butt" test with VAG-COM on S3's
pure Aug 27, 2004
  1. pure
    pure Member
    340
    Hmmm, not sure about how accurate this dyno test is using vag-com. But according to the tests measuring block 005 and 120. I am producing 333.8 (Nm) Net Torque, and 248 bhp at the wheel, with 221Lb-ft torque at the wheel.
    The Bhp figure doesn't sound right to me. I't was done using the weight of the car as 3355lb. (1525kg)
    I am running 21psi of boost, which thanks to my MBC is sustained for a lot longer than average.
    Does any1 else have vag-com and a chipped S3 they could do similar comparison.
    I've attached a plot of my actual boost vs requested boost for any1 that is interested also.
    Greg
  2. Drill
    Drill Member
    928
    Hmm, your Torque sounds a bit low too dude /ubbthreads/images/graemlins/confused.gif My A3 was dyno'd at 329 Nm after re-map. I would have thought the S3 gap would be more /ubbthreads/images/graemlins/crazy.gif
    /ubbthreads/images/graemlins/beerchug.gif
  3. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    Remember this is vag-com guesstimate!
    Rich
  4. Doesn't an S3 weigh 1375kg? Could be wrong.
  5. pure
    pure Member
    340
    Im going to get some better logs, the road I was doing the tests on wasn't completely flat, and very twisty :-/
  6. AL_B
    AL_B Well-Known Member Team Daytona Audi S3 DSG
    1,775
    215
    [ QUOTE ]
    [/ QUOTE ]
    The pre-facelift models quoted weight is 1375kg.
    The facelift models weigh a little bit more, about 1460kg.
    See this post...
    S3 Weight
    AL
  7. pure
    pure Member
    340
    Yeah, so the weight I used was about right considering there were 2 of us in the car too.
  8. RichA3Turbo
    5,089
    S3's are right lard *****! My A3 weighs 1246kg. Will be removing the spare wheel, rear seats and sub .etc for the upcoming trackday... should be pretty bloody rapid with 300lb/ft /ubbthreads/images/graemlins/grin.gif
    VAG-COM wont be to accurate anyway... Probably doesnt account for transmission losses .etc at the wheels.
    Rich
  9. AL_B
    1,775
    215
    [ QUOTE ]
    [/ QUOTE ]
    Yep, fat as ****! /ubbthreads/images/graemlins/smile.gif
    AL
  10. pure
    pure Member
    340
    The VAG-COM dyno is supposed to be pretty accurate, on some other forums, they compared vag-com results with actual dyno results and they were accurate within a couple of BHP.
  11. AndybS3
    AndybS3 Member
    233
    Wouldn't the coast down part of the butt dyno account for transmission losses?
    I think I've read somewhere that the ecu or Vag-Com can only read upto just over 1.5bar is this correct?
  12. pure
    pure Member
    340
    The coast bit is supposed to do the "drag" part of the equations.
    Not sure about max boost readings on vag-com.
  13. DuncS3
    DuncS3 Member
    289
    1.5 bar is the maximum (or maybe 1.55)
    Dunc
  14. pure
    pure Member
    340
    Ok, off and on it has taken me all day to get some figures from the data I logged last night, I'm still learning vag-com, but this is a dyno plot of the at the wheel power figures of my S3.
    I have no where near enough info logged, so will be redoing it this weekend and need to tweak the vag-com to log faster than it does currently.
    ANyway....I'll shut up....what do you think of this dyno? does it look right considering the data that I have collected?
