DV's a little help please
666markyboy Mar 16, 2009
  1. 666markyboy
    666markyboy Well-Known Member
    1,236
    57
    I dare say it's been mentioned many times before but i'm strugling to find my answer via the search function...
    What are the real world advantages of fitting a forge recirc dump valve ?? i know the oem's are prone to leaks but other than that it won't make me any more power will it ?? i'm hopeless when it comes to turbo engines and i just can't quite get my head round why someone would wanna fork out £80 for something that the oem version does just aswell for a fraction of the cost.... i'm an engineer so all i need is mechanical explination of why it's a good investment :keule:
    regards Mark
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
    The forge DV/recirc valve has a metal piston in it whereas the standard valve uses a rubber diaphram which are prone to splitting. You wont see any more power and there are a lot of owners on here running the standard valve with a remap without a problem. It really just depends on whether you want to replace the standard valve whenever the diaphram splits or spend the £80 for the forge vavle which should last longer.
    My car had a forge valve when I bought it so I cant comment on the standard valve but I have had turbo cars before running DVs with rubber diaphrams that would regularly split. Personally if I was you i'd keep the standard valve unless it was causing you problems.
  3. ty160
    ty160 s3 tys
    87
    well have just gone for the forge splitter r valve my self is more expensive but gives audio sound off like a blow off valve plus is realiable and adjustable for the boost so if ya plannin a remap got told this would be better but many on hear say dont like the dump valve sound but sounds fine to me lol not to chavy
  4. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    the splitR valve isnt chavvy at all its not like a proper dump valve i like the subtle sound of my splitR, think people are to quick to slate it when they havent heared one
  5. ty160
    ty160 s3 tys
    87
    i agree like the sound my splitter r makes to
