  1. JayA3sline
    JayA3sline Active Member VCDS Map User
    653
    154
    43
    Just bought a DV+ and installed it today into my audi S3 8P 2011. At the moment running on a superchips bluefin remap 310bhp. This little gadget is blooming brilliant... The lag is definitely improved and accelerator response is much better with improved boost control!
    Highly recommend for £100!
    mechanic69 likes this.
  2. mechanic69
    mechanic69 Well-Known Member VCDS Map User Gold Supporter Audi S3 DSG
    1,464
    553
    Snap, same car same map, great responsive drive. Great sound if you don't want the chav boy flutter.
  3. JayA3sline
    653
    154
    43
    I must admit I did like that blip in the exhaust and did notice it wasn't there. I have read that you can remove the spring to get it back but then it kind of defeats the whole point of having it (apart from durability). Still early days will see how I get on with it. You had yours on long?
  4. KevinF
    KevinF Member
    68
    Jay hi,
    Fitted mine yesterday onto my A3. Really pleased too with the purchase. You fitted the carbonspeed intake yet?
    Kevin
  5. Madpete
    Madpete Member
    64
    Having mine fitted on Saturday in my remapped 2.0 tfsi A3, looking forward to seeing what difference it makes.
  6. JayA3sline
    653
    154
    43
    I did that today also. I didn't bother with the bolts as it's so blinking tight to be able to get the torx driver in there but it sits there comfortably which is good enough for me. Bit like yourself not sure if it's actually benefiting but definitely looks better cheers
  7. JayA3sline
    653
    154
    43
    Takes 5mins to fit yourself... I'd be out there tonight doing it! simple
  8. mechanic69
    1,464
    553
    Still get a nice blip in the exhaust, did you make sure the pistons and springs are really oiled up before fitting? Had mine a month or so but took it off last weekend to make sure it was fully lubricated after reading other advice.
    easy to fit even with the engine cover on, screws a bit fiddly but do able
  9. s3_trev
    s3_trev Northern Ireland Gold Supporter Audi S3 Team Brill Red
    1,866
    644
    This is on my list. I dont think ive seen anything other than positive, or neutral at worst, feedback on these.
  10. JayA3sline
    653
    154
    43
    I made sure the brass piston was oiled up, to prevent the metal on metal noise. But that was all. I didn't really have a long enough drive to be fair but I'll do that in the next few days to play around
  11. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,027
    553
    mine is quite loud. what about yours guys?
  12. JayA3sline
    653
    154
    43
    Louder than without it?
  13. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    886
    Mines been fitted now for about 6 months and had no problems with it so far. Boosts easier and also holds boost for longer which is good in my books.
  14. S.
    2,027
    553
    yes. louder than oem one?
    mine wasn't that loud at the begining. and now is as loud as it was my forge vacuum operated dv. strange..
  15. JayA3sline
    653
    154
    43
    Very strange. There's never really consistency with any products, however I think the DV+ has been one of the most positive little items around at the mo. Just makes me want to get in and drive hard! Does the re oiling have to be done every now and then or one application enough?
  16. crazylegscrane
    crazylegscrane Active Member
    253
    66
    I'm getting one of these on tomorrow and will be interested to see how it performs.
    I've mostly read good things about these with the odd story of an issue but for £100 I will give it a go
  17. JayA3sline
    653
    154
    43
    Had a good drive today and I still can't believe how good it is. Worth every penny!
  18. mechanic69
    1,464
    553
    I was told it didn't need any maintenance and it doesn't see much heat so the oil doesn't burn off. Only issue is I'm not sure what oil you are supposed to use. Guess engine oil is best. It wouldn't hurt to check once a year as it saves where on the turbo. I'm going to check it every service cos its easy to do.
  19. JayA3sline
    653
    154
    43
    Quite agree. I used engine oil anyway so that suits me and no unknown noises produced = winner!
  20. JayA3sline
    653
    154
    43
    So been over a month now since had this installed and recently been noticing a more and more jerkiness returning... Not as smooth as it once was. I did lubricate the piston as instructed but I'm going to take it apart and re oil... I didn't lube spring though, is this required? Anyone else noticing the benefits degrading in time?
  21. prt57
    prt57 Well-Known Member
    849
    262
    The instructions do not say to lube the spring but I did. I just made sure that my fingers were oily and wiped over the springs and other components. I did give the piston a good coating and also made sure that it ran freely up and down in the black housing. No issues since.
  22. JayA3sline
    653
    154
    43
    As expected... The DV+ piston was dry as anything... I have re- oiled the piston/spring and inside of the black cradle... It won't be dry again let's put it that way. Going to have a drive in a bit so hopefully shall see an improvement as I had when I first installed it
  23. Compkiler
    Compkiler Active Member
    792
    226
    43
    Hmmm are there reall gains in performance with this or is it just another engine upgrade to say you've got it? lol (you know exactly what I mean)
    Serious question.... If it does make a noticible difference in performance/responsivness, then I will buy one! :)
    Oh and another thing, in 1st gear, mine definitely is jittery and not smooth... any ideas? Mines a manual!
    I always pull away slow and change to second asap
  24. JayA3sline
    653
    154
    43
    Not so much gains mate but more of taking away the jerkiness and is much more responsive as the boost pressure is gradual and constant as appose to on/off with the OEM version. You can definitely notice the difference and if it makes your ride smoother it's 100% worth the £100!
  25. Compkiler
    792
    226
    43
    Ok cheers bud
  26. JayA3sline
    653
    154
    43
    If that wasn't good enough... Put it this way I've just driven 15miles with it re oiled and my god it's a new car, makes the car drive so smooth and so much more responsive! Buy it!
  27. Forbzeeee
    Forbzeeee Well-Known Member VCDS Map User Team Sepang Audi S3
    935
    424
    I'm interested in one of these but I think I am going to wait until more people have got them and given feedback.
    Jay do you think you will have to keep re-oiling? It's strange that the instructions do not say lube the spring but you those of you who have say its much better.
    Brodster, have you re-oiled yours?
  28. JayA3sline
    653
    154
    43
    It may have been because I didn't use enough oil as I maybe was a tad on the cautious side. But this morning it was bone dry and signs of rubbing was apparent albeit very slight. As mentioned before I can't see why the spring would need oiling but the piston and perhaps the cradle once lubed is definitely noticeable. Even in sports mode (DSG) the change down is no where near as harsh as it use to be... It's literary a 5min job so will definitely be checking as of service intervals for peace of mind.
  29. s3_trev
    1,866
    644
    Same here mate. I find the s3 8p is quite difficult to change smoothly from 1st to 2nd. I really need to watch the clutch and throttle more so than any other gear.
  30. Compkiler
    792
    226
    43
    Ye exactly, well if this thing helps with that im getting one!
  31. JayA3sline
    653
    154
    43
    Morning gents
    I've had the DV+ fitted for quite a while now and the last few months have noticed a fluttering sound from the car when idling/ revs drop when pulling away. Firstly, does anyone else has this flutter after adding this DV+? And secondly I never did notice it first of all but it's actually starting to affect the performance of the car now as its almost as though I have a boost leak (which audi have said it sounds like the back pressure) and superchips have also said it sounds DV related. I'm guessing with the DV+ having such a small orifice for the air to travel through it may be causing this flutter? I regularly lubricate but I'm going to swap back to the OEM version to see if the boost leak is Dv+ related.
    Any thoughts?
  32. Charlie23
    Charlie23 Active Member
    617
    130
    43
    Which DV+ did you buy?
    I'm looking to get 1?
    I seen the GF DV+ is that the beast on the market?
  33. JayA3sline
    653
    154
    43
    GFB one. Strange thing is, when I first had it on it was brilliant and considering it's made from brass it really is an engineered piece of kit. And I did feel the benefit of it instantly without the flutter. It's only been recently its occurred, which makes me wonder if it's leaking elsewhere... OR if it's a common thing then perhaps I just wasn't aware of the noise at the time and I'm just paranoid about it now I've heard it.
  34. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,234
    386
    To rule out the DV do you still have your OEM DV, fit that and see if the problem persists.
  35. JayA3sline
    653
    154
    43
    Waiting for the engine to cool down then that's my next avenue... Definitely boost related as I even get the whistle sound when my foots down of the boost escaping. Perhaps may try with the stock stiffer spring too to see if that has any difference
  36. S3_Mat
    S3_Mat Active Member
    550
    192
    43
    I believe there was a revised version with a black plunger inside for k04 cars. Might be worth while checking which one you purchased.
    Also they shouldn't need oiling (except a dab of engine oil on install). There will be a bit of oil vapour in the boosted system that will make its way through to the intercooler and the DV. I have had mine on for 8k miles now and it still boosts and holds fine with minimal lag. I get all the usual flutters and noises as when it first got installed its great
  37. JayA3sline
    653
    154
    43
    ^ interesting... Will be checking the web for that revision then. I'm assuming the revision is on the GFB DV+? My OEM was the black plunger type
  38. Chris****
    Chris**** Member
    9
    Ive got mine today, and withing 5 minutes it was on. Not driven it yet, but only after i had installed it i read about lubing the brass piston :( so out again, oiled and back in. Hardly difficult luckily.
    As said, i would not lube the **** out of it, but use engine oil (as it says in the instructions) rather than any grease etc.
    Quite a bit of travel in the brass piston though. Have to hold it so it wont fall out when installing. But seems to fit perfectly.
  39. Flexiblemouse
    Flexiblemouse Active Member
    258
    60
    I have had my DV+ since February and an happy with it overall. You do get better throttle response and it holds boost better than the OEM valve. However the noise can get annoying after a while, and the performance of the valve will degrade over time if the piston is not oiled semi regularly.
  40. JayA3sline
    653
    154
    43
    Ok so I've reverted back to OEM version and I'm still getting the fluttering so the DV+ is fine. Must be some other boost related issue. I've always used engine oil to lube it however it's always been bone dry when I get round to doing it again. I did notice some scoring around the piston but it's not the cause of my issue anyway.
    Headache!
