DV relocation
Broken Byzan Jul 4, 2009
  1. Broken Byzan
    13,237
    465
    So anyway, while at GTi inters my AIT went off the charts, so i have deceided to lower the FMIC into the airflow better and make use of the space behind the S4 bumper. As such i need to extend or replace some pipework.
    Would it be of benefit to me to move the DV to the cold side by buying a T peice rather than a straight join?
    What are the advantages?
    Cheers:thumbsup:
  2. aragorn
    18,442
    847
    not sure of the advantages, but for one its going to mean a much longer pipework run back to the inlet pipe, which probably isnt a good thing?
  3. Lee Goodall
    Lee Goodall Active Member
    2,279
    I don't think there will be any advantage relocating the DV?.. Yours is a diverter and not a dump valve (atmospheric) isn't it mate? If so like Aragorn said you'll need a really long section of pipe to run the diverted air back unless you're planning on routing it back to the cold side (after FMIC) too?
  4. Broken Byzan
    13,237
    465
    Yeah Diverter type, thats cool, i was just thinking with having to drop the FMIC it wouldnt have been difficult to put a T in. Some of the A3 guys seem to do it, i wondered if there was an advantage
  5. Lee Goodall
    2,279
    I suppose if you were altering the turbo setup (big turbo etc.) then it'd free up some more space but other than that I can't see a benefit.. I may be wrong though.
