  1. takworldwide
    takworldwide Member
    158
    Hi all, does anyone know where the best place i can get the small rubber pipe connected to the top if my DV as it is starting to perish, car seems alittle down on power(not sure if its the pipe or coilpacks).
    Thanks.
  2. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Any motorfactors shop would sell vacuum pipe suitable.
    Sadly, when mine broke the only place open was halfords so I ended up spending £13 on a length of silicon hose....RIP OFF!!
  3. Dani_B19
    9,253
    377
    Ebay has loads on their, pick your colour aswell
  4. takworldwide
    takworldwide Member
    158
    Thanks A3TOM, do you think this would cause lumply idle/reduced power? As i hear coilpacks never go on an AGU?
  5. A3ster
    A3ster Member
    87
    Coil packs never go on AGU, is this correct? Begining to think AGU was the best engine they did.
  6. A3Tom
    3,504
    14
    My mates Golf (AGU) had the coil packs go tits up on it a couple of years ago.
    Currently though my AGU has been solid as a rock and I've not had anything go wrong apart from the temp sensor.
    T
  7. takworldwide
    takworldwide Member
    158
    sorry to be a pain but does anyone know the diameter of the vacuum pipe, im guessing 5mm???
  8. Dani_B19
    9,253
    377
    You can go 5mm but for the best fit im sure its 3mm
  9. A3Tom
    3,504
    14
    Mines 4mm. Buy some new small jubilee clips too.
  10. Emmo
    Emmo Member
    232
    14
    get 4-5mm internal diameter as the 3mm is a tight fit, especially if its an aftermarket dump valve. The vacuum/fuel hose is abt £1 per metre from motor factors.
    This colud be the reason why your loosing power, when I had my a3 one of hoses came off the dv and it did lose power and felt sluggish.
  11. abdus
    abdus Top Gear VCDS Map User
    1,827
    I think in its generation, yes
    were they original coilpacks? I've yet to come across an AGU engines with bad coilpacks...the ignition amplifier is usually the main problem
  12. abdus
    1,827
    just go to an Audi delaer and bring the pipe with you. They don't have that as a part no. on their system (well mine didn't). Try to explain what it is.
    They will come back with a metre of it and that for free. LOL
    (Well I got mine like this way)
  13. A3Tom
    3,504
    14
    As far as I'm aware they were, his car was an ex demo so he was the first real keeper so I think they were the original ones.
    Thinking about it, I think the stealer changed them on a recall when it went in for a service years and years ago. He's not had any problems since though (its up to 140k now)
