dump valve??
Lacey123 Jun 23, 2009
  1. Lacey123
    Lacey123 Audi S3
    33
    what is the best dump valve too get?
    i want the wooosh noise in my life?
  2. subby
    subby Member
    126
    you wont really get it as s3's recirc the pressure. The whoosh noise is the boost pressure getting released to the atmosphere, which the S3 will not like and mess with the ecu.
    Best thing is to get a forge or similar dump valve and a panel filter (pipercross for example)
    And also ive heard of people drilling hole in their air box for the whoosh noise on s3's, but i would never do that myself.
  3. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    The best ones are the ones that have no whoosh noise. if you want the noise without compromising on performance, get a Forge recirculating valve (FMCL007P) and then a BMC CDA or something like that. You get the noise without leaking the air to atmosphere and creating lag.
  4. A3tell
    A3tell Member
    239
    recomend either forge 007p or you can uprate the standard one to a bosch 710n unit, which comes off a tt225bhp, does same job at fraction of cost!!
  5. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    forge splitR valve its not very wossshhy but its about all you can do by fitting a dv to an a3/s3 with out eml issues, as for turbo lag and and loose of power thats never going to happen in real terms
    im surprised no ones come here calling you a chav yet
  6. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Chav!!.
    .....well someone had to ;)
    Panel filter and a 007 will give you a bit more 'whoosh' but it'll never EVER be anything that dumps to atmosphere.
  7. emery1990
    emery1990 Active Member
    1,068
    thats what i just got, diverter valve and panel filter, cant hear anything difference, or feel yet really, just hoping its my broken pipe thats making it feel like this,!
  8. Boro&Beth
    Boro&Beth Member
    172
  9. S3 HODGE
    S3 HODGE Brown passenger seat.
    1,200
  10. DPM
    DPM Site Sponsor Site Sponsor
    5,041
    212
  11. dela
    dela Member
    262
  12. 1animal1
    9,978
    congratulations....
    chav
    :D
  13. Boro&Beth
    Boro&Beth Member
    172
    PM sent :hi:
  14. g10chy
    g10chy Member
    155
    I have fitted my 007p the other day and i have noticed that the dump sound is alot louder then the standard bosch valve.
    Should this be the case or am i leaking boost?
  15. Boro&Beth
    Boro&Beth Member
    172
    Have you noticed a drop in performance?
  16. g10chy
    g10chy Member
    155
    Not sure as i have only owned the car a few days before putting the new valve on. Should you be able to hear the valve re-circ the air fairly loudly around 3kish revs?
  17. Boro&Beth
    Boro&Beth Member
    172
    Wouldnt say ours is fairly loud with a standard DV on but you can hear it if you listen for it
  18. 1animal1
    9,978
    no the 007p should sound more..... you wont have a drop in performanxce with that unless your using the wrong spring
  19. AwesomeSarah
    AwesomeSarah Member
    726
    http://www.awesome-gti.co.uk/product.php?xProd=6775&xSec=459
    That one will fit
    Tested on the TT forum to have the best gains.....
    But as has been said , can`t use proper dump valves on the 1.8T
    You could always try turning the 007P round to see if it gives any more sound
    It worked on my son`s MK4 Golf 1.8T , now he is more impressed ;)
    Sarah
  20. Boro&Beth
    Boro&Beth Member
    172
    Or you could buy my Split-R :D
  21. AwesomeSarah
    AwesomeSarah Member
    726
    Or you could buy his splitR ;)
    Loudest sound you will get from a DV
    Sarah
  22. morgan306
    morgan306 Member
    142
    Boro&beth,how much do you want for it?
  23. Boro&Beth
    Boro&Beth Member
    172
    Sorry mate, this sold :(
  24. morgan306
    morgan306 Member
    142
    Oh ok, not to worry.
    Do these valves make much of a noise or do they sound like more of a quiet sneeze?
